Master
- Posted on Aug 11, 2011
Re: Case 580 super e. case 580 k both tractors will not...
You are having the typical shuttle failure. There is a bellville type spring that returns the clutches when pressure is taken from the clutch pack. That spring will fail with time, it is nothing you did.
grinding noise when accelerating and turning right, no noise when turning left. I changed the wheel bearing and the cv joints and still the same problem. Thenoise is louder when cold.
regcure pro licence key
How do you replace a touch pad on lg microwave model lmv1630st
the lights under the microwave will not turn off, they just 'flick' when I select them to be turned off and stay on. They will also smell 'hot' after a few minutes of being on. I have also found that it is a **** shoot when it comes to heating food
2005 Civic Rear Window Defogger light (only) is out?
The AC off indicator light in on and the AC will not turn on. Every thing works (fan ect.). Is this an electrical issue with the fuse. If so, where is the fuse to the AC on my 2002 S500?
location of fuel pump driver for x-type jag
abs and brake light on. Car bogs down, speedometer erratic, feels like brakes are dragging
Generator switches when power goes out gen turns on and works when power comes back on gen turns off but transfer switch dosent go back to normal power
The freezer has ice crystals forming on everything in it, it is like a freezer that needs to be defrosted
where and how many relays control the fuel pump on a 1993 toyota camry
v70 volvo 2004 starts but wont idle. Car would start briefly and shuts down immediately.
Seems like most bulbs are not lit or very dim
Items closest to the freezer and near the back within the refrigerator seem to freeze. Refrigerator setting is already below normal. Condenser coils were already cleaned within the last year and it seemed to be ok for a few months after. On another note, the ice maker is not working. It seems that the water supply line feeding into the icemaker freezes up with a chunk of ice and only if the freezer is defrosted then the ice maker seems to start working again.
Dashboard gages and lights stopped working, electric windows stopped working, red security light stopped coming on, and engine will start for 1-2 seconds then die, overhead lights don't work when doors are open
sounds like printing but blank paper comes out
