SOURCE: fabric softener won't empty
as you have said you have cleaned out all of the soap drawer a good place to start is assume the problem could be the water supply solenoid, the water not getting through, remove power plug, the lid, and test the solenoid for open circuit, and replace if needed, if this has helped please rate me
SOURCE: Fabric Softener remains after load done
You should make sure that your inlet to the machine flows with rather good pressure. I tell u this for your soft tray requires water, also your rinse.
SOURCE: Whirlpool Frontloader - the bit
you can remove the top cover of the washer( 3 screws alongside the top rear of unit) and top will slide back and off, the dispensor is right there with sort of a tear drop shaped cam and lever.Make sure thats in tact. start the washer , and youll see it cycle foward and back if broken youll need to replace the part, dont think the line is blocked (if it was youd get fabric softener overflowing out front), im thinkin the water never gets to that area of dispensor. id start with the lever system
SOURCE: Fabric Softener tray blocked
You need to remove compartment from the m/c, and thoroughly clean every part, particularly the conditioer compartment and the piece inside it.
SOURCE: Bosch Washing Machine Softener Tray not emptying
You need to replace the cold water inlet valve. If the machine is older than one year it may be clogged on the side that moderates the cold water to the bleach and softener compartment. Replacing the valve fixed the problem. During the cycle when the softener dispenser fills it should fill quickly and no or little water should be seen in the soap dispenser area. If a lot of water goes into the soap dispense and little into the softener area the valve is clogged.
