If your computer came with
a motherboard disc the sound drivers could be on it click start control panel sounds and
audio,volume,advanced,speakers select the appropriate speakers from the drop
down list or navigate to the device manager scroll to system devices + to
expand,system speaker right click properties then select use this device
(enable) also you might check
administrive tools computer management device manager scroll to sound,video and
game controllers you might see a yellow question exclamation mark? ! or a red X
Right click to reinstall drivers
sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers)))
also audio you will find 3 drop down lists make sure you have the correct
settings there
also
sounds and audio devices select advanced there might be a tick in the mute box
untick it
if his does not fix the
problem
sounds and audio devices you can adjust the volume there also select speaker
volume you can change your settings there you can also tick in the box place
icon in taskbar for any further volume control settings you will need to right
click on the volume icon system select
adjust volume
the speakers plug/outlet is
usually at the back of the computer you will have to open up the computer
to check the lead attached to the rear of the input plug make sure the
connection is good
try cleaning your computer of dust using a fine air blower from a
compressor making VERY sure that there is no MOISTURE in the air line
specifically around the sound card and the CPU central processing unit dust
causes static to build up in a computer hope this
helps
*Turn off your Dell laptop.
*Connect speakers to the speaker control box.
The speaker control box varies depending on the speaker system you have.
Two-speaker systems will have a female jack on the back of one speaker that you
plug the other into the second speaker. If your system has a sub-woofer, all of
the other speakers will plug into it. The connecting cords are color-coded to
the jacks on the back of the control box.
*Plug an audio cable into the
"Audio-In" port on the back of the control box. If the audio cable is
color-coded, it will be green.
*Plug the
other end of the audio cable into the headphone jack on your laptop.
*Plug the
speakers' power cord into a surge protector to protect your system from power
surges. *Plug the surge protector
into a wall outlet.
*Turn on your speakers and set the volume at a
medium level. Be prepared to turn the volume up or
down after you turn your laptop on.
*Turn on your laptop and confirm that sound is
coming from your speakers.
Thanks for rating
Good luck
