7701V  Responder SST Remote Logo
A
Anonymous Posted on Aug 10, 2011
I dropped my viper alarm in water. I reached in and grabbed it right away. only the battery was wet. However my alarm will not activate to lock and unlock my car. The alarm remote will turn on once the battery is inside. (It makes the squaking sound.
5 Related Answers
Anonymous
  • 22 Answers
  • Posted on Dec 04, 2008
SOURCE: the battery was taken out
Put the key in the ignition turn in two clicks. Take the key out hold down the program/valet button on the remote start then hit the unlock button on the remote.
Anonymous
  • Posted on Feb 28, 2009
SOURCE: viper 5701 remote
read the owners guide look at page 11 remote control programing you have to follow the instructions after your in the programing mode go to page 12 look at the unlock symbol and finish the programing
Anonymous
  • 6 Answers
  • Posted on Mar 14, 2009
SOURCE: Brake lights won't flash when activate alarm system
Do the normal indicators work? If not it could be the flasher unit. If they do you have a faulty relay inside the alarm
Anonymous
  • 87 Answers
  • Posted on Jun 03, 2009
SOURCE: my viper alarm remote just beeps flashes TX and
Try to reprogram this. If this routine does not work please let me know and we will try something else
Anonymous
  • 53 Answers
  • Posted on Jul 12, 2009
SOURCE: I press the lock door/alarm activation button and
sounds like the remote is not program try programing the remote again
Viper Alarm app says Not Armed but locked
If the Viper Alarm app is showing that the alarm is "Not Armed" but the vehicle is locked, it is possible that the alarm system is not communicating properly with the app.
One solution is to try resetting the alarm system by disconnecting the car battery for a few minutes and then reconnecting it. This can sometimes help to reset the communication between the alarm system and the app.
If this does not work, it may be necessary to contact Viper customer support for further assistance. They may be able to provide troubleshooting tips or suggest a software update for the app or alarm system.
Cannot turn my car alarm off. Viper 2001 Toyota Tacoma. Tried turning ignition on position valet button 5 sec turn off ignition doesn't work
could be the backup battery in the alarm that is at fault, this would keep the alarm activated due to its low voltage, the battery inside the unit has to be at a certain voltage, if it does not reach this voltage the alarm with activate.
My Hornet alarm doesn't chirp, activate, or go off anymore. I've tried to check the valet mode, but it doesn't do anything. The remote still locks and unlocks door's and it cranks.
My car alarm doesn't chirp all the time, but it still unlocks the ...
forums.anandtech.com > Social > Off Topic
AnandTech
Feb 3, 2003 - 11 posts - ‎7 authors
My car alarm doesn't chirp all the time, but it still unlocks the doors. ... Distributed Computing. ·, Security. ·, Social. ·, Off Topic ... The rest of the electrical systemseems fine. ... Just read the owners manual and find out to to re-enable the ... but like when I arm my alarm it arms but then it'll go off for no reason.
Alarm Troubleshooting Help Tips - Dr.Detail
www.drdetailshop.com/TROUBLE.html
When you try to start the car the alarm goes off.. It could be your battery. 3. Try to start no sound, nothing lights up, alarm doesn't work. It could be a loose battery ...
Viper Alarm won't chirp help!! - 12 Volt Forum : Car security ...
www.tintdude.com > ... > 12 Volt Forum : Car security / Convenience
Sep 11, 2006 - 7 posts
posted in 12 Volt Forum : Car security / Convenience: Hi I am new to this site ... Myproblem is when I lock it it won't chirp or roll my windows up ... If I hold the lock button the siren will go off,and if I press and hold the AUX my windows will go down. ... It won't chirp when activated or when I hold the arm button.Missing: hornet
How To program DEI Viper Python Avital Sidewinder Valet ...
? 3:34
https://www.youtube.com/watch?v=r01ntAXGxBw
Mar 10, 2011 - Uploaded by Lessco Electronics
hi I have the viper 7142v alarm system,tge problem is I only had one remote,I ordered a spare but ... My alarm only chirps when i am programming lock and unlock functions. it does not ... As soon as I connect car battery my alarm goes off. ... I obviously don't have a remote, and it doesn't have a valet switch.
1helpful
I purchased a avital 4103 remote start kit.i also have a viper 300 esp alarm system installed. my question is can i use the avital remote control to activate the viper alarm and start the car along with...
Avital and viper remotes even though they look the same, they operate at different freqs. Im a retired alarm installer i could never get them to interchange.
4helpful
2answers
Disable viper alarm
Yes the best way is disarm the alarm and put in a Valet Mode
To activate the Valet Mode do the following:
There is a push button or toggle switch to disable the alarm (to engage the valet mode). Without knowing where this
switch is you won't be able to disconnect the alarm.
1. Put the key in the ignition and turn it to the "on" position.
2. Flip the toggle or hold the push button for at least 5 seconds.
3. The LED. light will stay solid on.
4. Turn the ignition off
5. Release the push button. If you have a toggle leave it alone in step 2
5helpful
2answers
Battery went dead,clifford alarm locked the engine
Assuming that all is well with the vehicle's electrical system (fuses, etc...), the following should work, as Viper/Clifford uses the "fail safe" method of starter disable, and it only works to lock out the starter when the alarm is functioning properly and in the armed state.
That system has a "starter kill" system. When the alarm is actived, the starter kill is engages, and won't let the starter get voltage from the ignition switch. First thing I'd try is connecting the car's battery while the ignition key is turned to the "on/run" position. Cycle the alarm to arm, then disarm, so that the LED is not blinking. It also may require using the manual override button/switch (with the key on) to reset the alarm. Should start after that.
If all else fails, reconnecting the starter wires back together (they are spliced and running through the alarm via a SPDT relay.
7helpful
3answers
The alarm doesn't chirp and no flash of my headlights anymore. Also the blue light stays on the little receiver/antenna on the windshield wheather it is locked or not. What is the problem?
sounds like the alarm went into valet mode. that's usually what a solid blue light means on most viper alarms. check your owners manual on how to take the alarm out of valet mode. with the 5701 alarm its usually done with the remote. hope this helps
4answers
Viper auto alarm
Change the battery in the keyfob..
Top Viper Vehicle Parts & Accessories Experts
oneStan
oneStan
ZJ Limited
ZJ Limited
Are you a Viper Vehicle Part and Accessory Expert? Answer questions, earn points and help others
