Frigidaire FEB27T5D Electric Double Oven Logo
Posted on Aug 10, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The oven door won't unlock even though self-cleaning has been cancelled
Anonymous
Level 3:
  • Frigidaire Master 43,501 Answers
  • Posted on Aug 10, 2011
Anonymous
Frigidaire Master
Level 3:
Answers
43501
Questions
0
Helped
10844146
Points
101584
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
Self Cleaning Oven Problem
heatman101
Asker's Testimonial " Wish I had read this first. I never would have usedthe self cleaning option. Thanks for the info!! " - amymrocks
My 2008 Maytag double oven the lower door is locked, no messages on display and the manual says to push 'CANCEL abd Cook & Hold' button but does not unlock the door
f your 2008 Maytag double oven's lower door is locked, here are some steps you can try to unlock it:
Press Cancel/Off Key: Start by pressing the Cancel/Off key. Wait for 20-30 seconds, then try to open the door. Sometimes this simple latch reset can do the trick.
Power Cycle: Turn off the power at the circuit breaker or fuse box for one minute. After that, turn the power back on. Allow the oven to cool for approximately 30-90 minutes, and then move the latch arm to the left to unlock the door.
Self-Clean Cycle Interruption: If the door locked during a self-clean cycle, select the "Self Clean" option, and then choose "Cancel". Wait a couple of minutes, and then try to start the cycle again. If the self-clean cycle was started by mistake, press the Cancel/Off key. The oven will need to cool to around 200°F (95°C) before the door can open.
Remember to ensure that the oven is cool and the power is turned off before attempting any of these steps. Hopefully, one of these methods will help you unlock the oven door! Your manual might prove helpful. Oven is Locked - What to Do - Product Help ' Maytag
4answers
Kenmore self cleaning oven 362.75471691
see to it the there was no stuck object or parts on the door parts...
Sep 30, 2008 • Ovens
1helpful
Scholtes FE46 and the door is locked. Also no clock/timer lights. Temp/function and oven work but is locked even though completely cold.
Here are a couple of things to try:
  1. Unplug the unit or shut off the circuit breaker for 5 minutes. Plug the unit back in or turn on the circuit breaker. Set the clock and gently try moving the door lock lever (is so equipped) or opening the door.
  2. Set the self-clean cycle again and only allow it to work for 15 minutes. Cancel the self-clean cycle and allow the oven to cool. Gently try moving the door lock lever (is so equipped) or opening the door.
Read through the following for mire info:
Appliance411 FAQ After self clean range oven door won open
Mar 25, 2016 • Ovens
My maytag super capacity plus won't unlock after
this would be the best source look at link i hope it help out
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&cad=rja&uact=8&ved=0ahUKEwjhpKi-i5TXAhVmyoMKHX_OAtMQFggnMAA&url=http%3A%2F%2Fproducthelp.maytag.com%2FCooking%2FWall_Ovens_and_Ranges%2FOven_Product_Assistance%2FHow_to_open_a_locked_oven_door&usg=AOvVaw3VNunJSAkZGld_PY0xGM3s
1helpful
2answers
H E L P !!! My oven made some noises this morning when my husband was wiping down the front of the oven door. Noise sounded like the "oven was going into clean mode"....but then only lasted...
Hello.
Please apply the solution this way!
To close an oven door when it's in the locked position and the door is open, press and hold the oven door light switch while following these simple steps:
  • Program the oven to self-clean.
  • Wait 20 seconds.
  • Cancel self-clean.
  • Wait 20 seconds.
To self-clean your wall oven, follow these simple steps:
  • Remove the oven racks.
  • Set your oven control to "Clean."
  • Select a cleaning time or choose a cleaning level: light, medium or heavy. For typical cleaning needs, we recommend that you select a cleaning time of three hours or choose the medium setting.
  • Select "Start." (To set a delayed start, see your Use & Care Guide.)
Note: For safety reasons, the oven door will remain locked until the oven cools down. When it is sufficiently cool, the door will automatically unlock.
Thanks for using fixya.
Sep 07, 2011 • Dacor Ovens
Tried to clean it. Door has locked and won't cycle open again. Help!
Hello.
To close an oven door when it's in the locked position andthe door is open, press and hold the oven door light switch while followingthese simple steps:
  • Wait 20 seconds.
  • Wait 20 seconds.
Note: For safety reasons, the oven door will remain locked until the oven coolsdown. When it is sufficiently cool, the door will automatically unlock Thanks for using fixya.
Sep 06, 2011 • Ovens
1helpful
Oven Door Locked
the oven door does lock during self clean, otherwise it will not work. however, the door is supposed to unlock after the oven has cooled. if it is still locked, turn the oven to self clean and wait about a minute and then hit cancel and see if the door unlocks. if not, there may be a probelm with the door lock mechanism. Joe
1helpful
Self-cleaning gas oven
Door lock motor has probably failed.....Self clean on many
ovens can be a self destruct mode. Door latch motors, sensor
probes and even the electronic controls can be destroyed by
this operation. On many freestanding stoves the lock motor is located in the right rear (looking from the front) with a long rod connected to the lock. remove the motor and unhook the rod from the motor cam. Sometimes bending a coat hangar into a hook and sliding from the right side into the lock you can unlock the door.
Wall mounted self clean convection oven by Frigedaire!
Unplug it or turn off the breaker
Dec 15, 2007 • Ovens
Top Frigidaire Ovens Experts
ZJ Limited
ZJ Limited
Paul Carew
Kell Le
Level 1 Expert
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
