SOURCE: Rings before KX-T7736 goes to voicemail
This is just the quick answer and may not be exact. System program 203 is the intercept time. It's probably set by default to 40 seconds. A ring cycle is about 6 seconds. Try adjusting that down to, say, 20 seconds and see if that works. I have your exact setup in my office, but I'm not in my office for the rest of today. I may get a chance to play with the timing on Saturday.
Carl
SOURCE: number of rings before going to voicemail on KX-T7630
Press the FWD/DND button, then scroll through the menu button until the screen shows "FWD No Answer time". Then use the number key pad to change from 000 seconds to 010 seconds (or longer if required). Then exit out of the menu.
SOURCE: My phone on our Norstar system rings & rings
Fress F985 u will get voicemail DN. Note down ur voice mail DN.
Go to programming of Norstar which will be F**266344 password will be 266344.
Dispaly shows u terminal and extensions.
press show
then next display will show u capabilities.
Press show then next display will show u FWD no answer.Press show then change put the voicemail Dn which u had written then next.
Now call will go to ur voicemail provided u have ur own presonal mailbox. If it is not there u will have to createe it otherwise it will go to general delivery mailbox.
Hope it will be helpful for u.
Thanks.
