Lithium ION batteries are usually rechargeable. The use mode for these batteries is that there are a set number of recharges that equate to the life of the battery. Usually that life is approximately 1,000 charges.
If you use your battery to 50% then recharge, you can do this ~2,000 times. As the life of the battery is used up, the maximum charge lessens which means where you may have had 8 hours of play time when the battery was new, you will only have 6 hours as the battery life is used up.
In order for a Lithium ION battery to recharge there must be at least a small amount of charge left as a "seed" for that recharge. If you drain a L-ION battery down to zero, it may never recharge again or the max charge will be reduced to an insignificant amount of the original full charge. eg instead of 8 hours you may only get 15 minutes, or 5 minutes, or no minutes.
You are much better off recharging when 50% depleted than using it up til your product stops.
L-ION batteries cannot be repaired only replaced. Most cheap products using L-ION batteries cannot have their batteries replaced.
Lithium ION batteries are useusally rechargeable. The use mode for these batteries is that there
used up.
Lithium ION batteries are ususally rechargeable. The use mode for these batteries is that there
used up.
This model was not made to have the batteries replaced. It is possible but the shaver body will probably come out very scarred in the process. Instead, the following replacement is suggested
This happened with my Canon Powershot A470. I sent it back to he manufacturer and they said I was using the wrong batteries. Even though the camera is supplied with two alkaline batteries, they recommend using AA NimH rechargable batteries.
I have the same problem with mine!! Had it about 14 months now too!!
Glad I'm not the only one... I don't know what to do! I have gotten
brand new rechargeable batteries and instead of getting 250 shots, I
only get like 20!
