I have a HDMI cable, however my cable box doesn't have the correct plug in for that connection. Some guy at the store told me to use my red, yellow, and white cableI have a HDMI cable, however my cable box doesn't have the correct plug in for that connection. Some guy at the store told me to use my red, yellow, and white cable
You can't post conmments that contain an email address.
The Samsung Television has 3 HDMI inputs, You would connect an HDMI cable from the Cable box to your television and go into a menu on the television to select the appropriate HDMI input.
New cable boxes should have the HDMI connection.
Most Flat screen televisions I've seen have an input button on the television itself. Pushing it should allow you to switch between inputs.
The red yellow and white cable are RCA jacks found on most all video devices. The red and white are audio and the yellow is for video.
Connect from the outputs RCA jacks on the cable box to the input RCA jacks on the television then change the television to the correct input setting.
This link is a picture of RCA cable http://www.audiogear.com/Resources/Adpt3...The red yellow and white cable are RCA jacks found on most all video devices. The red and white are audio and the yellow is for video.
This link is a picture of RCA cable http://www.audiogear.com/Resources/Adpt3RcmM4m.jpg
HDMI stands for High Definition Multimedia Interface. If you want to use the HDMI connection you need to get your cable provider to get you a High Definition cable box with the HDMI output.
To get the best quality picture I would use the HDMI connection.
I've never seen a television without the RCA Red Yellow and White connections though.HDMI stands for High Definition Multimedia Interface. If you want to use the HDMI connection you need to get your cable provider to get you a High Definition cable box with the HDMI output.
Sounds like a problem with source recognition. Could have a problem with input coming into the tv such as cable connection problem, loose wires, etc. Try reseting the cable box and removing and reinstalling all of the cables in the back and the cable box.
Reset the cable box,by unplug,replug it an hour later.So the box will upgrade it software.Should work after this.Not,there a HDMI cable,U use this cable.Replaced it.Don't work,after this,take another tv test the tv incomming signal.See,if the cable box is the cause.Not,than ur DLP tv Main Tuner board is dead,must replaced to solved this problems.
This sounds to me like one of two possibilities. First, check your ballast. If you're going through bulbs faster than you think you ought to be, you may have a ballast that is overloading. Its the 3" x 8" circuit board that connects directly to the bulb. They are plentiful and often cheap. Thats what I'd try first. If that doesnt' do it, I would invest in a new power supply board. That the board that the tv power cable hooks directly in to. This should give you a start, Comment back if you still need further help. Good luck.
