SOURCE: Won't idle without choke
The pilot jet controls the air/gas fuel mix at idle . If the jet gets plugged up not enough gas gets to the emgine at idle. You will need to remove the carbs and float bowls and clean them, paying special attention to the pilot valve. Count the number of turns to remove the pilot screw and replace the same number of turns then turn counter clockwise 1/2 turn.
A “very helpful” rating for this answer? Thanks!
SOURCE: 2000 Yamaha TW 200 lacks power, has a high speed
If your header is glowing red, you are getting way too much gas in the cylinder, and it is burning it in the pipe. You either have a misadjusted float, or your timing is off. You could be as little as a tooth off, and have a problem. I would suspect the carb flooding more so.
SOURCE: 2002 YAMAHA BANSHEE WILL NOT REV
I have a 2004 banshee at the yamaha dealer being worked on.It would not run when i took it up there they cleaned the carbs and put it back together it will start but when you rev it, it holds itself wide open and wont shut down unless you pull the plug wires.they also checked the floats in the carbs said they where ok. they think it is a vent issue with the gas tank or the fuel shut off valve.IS THAT POSSIBLE
SOURCE: 1997 Yamaha Kodiak 400, hard to start, once you
I would follow the fuel line all the way check the filter it should be inline and check the pump as well i would say its one of them two.
SOURCE: I have a yamaha
Check that the intake manifold is not cracked or separated, extra air might cause you to need the choke. Some times the first carburetor cleaning does not do the trick. Take the carburetor off again, take out the slow jet, and shoot through it with cleaner to make sure it is clear. Now shoot through the passageway of the body and make sure that the body of the carburetor is clear . When all passageways in the body are clear then reassemble and put it back on. If the air screw is set correctly you should have a machine that idles.
Testimonial: "Thank you very much Heimlich. that should do the trick. "
It could be that your crankseals are leaking. The carbs rely on crank pressure to operate properly. If the seals are leaking it can cause very inconsitent issues with how the ski will run. Also the seals can ruin a stator if they are leaking. Pull the flywheel cover off and see if it is wet with oil inside. I think you need a stator to fix your problem, and the ski will still run with leaking crankseals, but if they are leaking they can shorten the life of your new stator. And yes stators are not cheap.
