Kenmore 64802 Top Freezer Refrigerator Logo
Posted on Aug 09, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Ice keeps building up on the freezer floor in my Kenmore refrigerator freezer. though I have turned the freezer setting down to cold from very cold, this continues to happen
  • Anonymous Mar 20, 2014
    How do I turn down freezer setting
Anonymous
Level 2:
President:
  • Expert 3,773 Answers
  • Posted on Aug 10, 2011
Anonymous
Expert
Level 2:
President:
Answers
3773
Questions
Helped
609017
Points
163
The drain in the freezer behind back lower panel
needs opening. You can see it at the bottom of the back panel
underneath the evaporator coils. (The cold coils)
Run Hot water in the drain until it clears or use a hairdryer.
When the defrost melts the water it goes down the drain
If the drain is clogged with Ice or ? The defrost water
overflows into the ref. or freezer
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
2helpful
I have a whirlpool refrigerator model #GT15HTYMQ81
The refrigerator is supposed to self-defrost approximately four times in every 24 hour period. If one of the components in the self-defrosting system fails, the refrigerator continues to try to cool. Eventually, though, so much frost builds up on the evaporator coils that the circulating fan can't draw air over the coils. There may still be a small amount of cooling because the coils are icy, but with no air flow over the coils, cooling in the refrigerator compartment is quite limited. Here's an inexpensive, though inconvenient, way to determine if the problem is with the self-defrosting system. Remove all of the perishable food from the refrigerator and freezer, turn the thermostat in the refrigerator to Off, and leave the doors open for 24 to 48 hours. (Be sure to have several towels ready in case the melting frost and ice causes the drip pan to overflow). This allows the refrigerator to defrost "manually." When the frost and ice build-up has completely melted away, turn the thermostat back to a normal setting. If the refrigerator then cools properly, it indicates a problem with one of three components in the self-defrosting system: Poor cooling is often the result of a heavy frost build-up on the evaporator coils. You can't see these coils without removing a panel on the inside of your freezer. A sure sign that there is a build-up is the presence of any frost or ice build-up on the inside walls, floor, or ceiling of the freezer. Such a frost build-up usually indicates a problem in the self-defrosting system or damaged door gaskets. The defrost timer The defrost thermostat (also called the bi-metal switch)
1helpful
Kenmore Refrig Model # 75922400 top Freezer. Freezer is freezing really good but frig is around 46 - 48 degrees at coldest setting. We discovered ice on vents in freezer and thawed them out with hair...
Sounds like a defrost failure.
Look on the back wall of the freezer from the inside.
If it is covered in ice your defrost system has failed.
Also check the fan motor in the freezer.
If it is not running it must be replaced.
Bottom frig is not cold enough. just connected after 1 yr
Ok do this. Boil some water in a pot then use that to defrost the freezer. This is caused by ice build up in the vent that is keeping the cold air from coming into the refrigerator. Make sure it is defrost completel though cause the ice that is built up is mostly inside and can't be seen. That will solve ur problem I guarantee. Then set the temperature to normal. Like half way. This keeps the frost from building up. Believe it or not as refrigerators get a bit older they actually get even colder and therefore frost build up is more likely. Since no refrigeration can be made completely leak proof, small amount of the freon has leaked out older fridge, and this actually cause it to get colder. You don't need a service technician just defrost then set to a lower setting thats it.
My freezer is working fine but refrigerator is not as much cold as it is suppose to be. Is there is a trip button somewhere I can check.
Could be a couple things. Turn freezer dial control to suggested setting---usually 5. turn fridge dial up. if you set the freezer dial to a higher number it will divert more air to freezer, turning down will divert more to fridge.
Clean coils in back or under fridge.
Is ice building up in freezer?
Are your door gaskets sealing?
Kenmore Elite ice maker doesn't work
Evaporator coils
If it still exists then there may be a problem with the refrigerant level or the compressor. You may need to consult with a qualified appliance repair technician to further diagnose the problem
Ice build up on freezer floor.
Hi, If ice is building in the freezer, you have a defrost drain hole plugged. Unplug the Fridge and then remove the rear panel off the freezer. There you will find ice built up in rain. Remove the ice (hair dryer works best). Once the ice is gone, you need to make sure the drain hole is open all the way. A baisting serringe with hot water works really well.
I hope this helps. Please let me know if I can assist you further. Please rate my answer so I know how I am doing.
Thanks
Vic
1helpful
My refrigerator is not keeping my food cold or frozen!!
Poor cooling is often the result of a heavy frost build-up on the evaporator coils or a condenser that is clogged with dust, lint, and dirt.
Evaporator coils Poor cooling is often the result of a heavy frost build-up on the evaporator coils. You can't see these coils without removing a panel on the inside of your freezer. A sure sign that there is a build-up is the presence of any frost or ice build-up on the inside walls, floor, or ceiling of the freezer. Such a frost build-up usually indicates a problem in the self-defrosting system or damaged door gaskets.
  • The defrost timer
  • The defrost thermostat (also called the bi-metal switch)
  • The defrost heater
If it still does not cool properly, there may be a problem with the refrigerant level or the compressor. You may need to consult with a qualified appliance repair technician to further diagnose the problem
2helpful
2answers
Water leaking onto floor
unplug it again , sounds like your drain line has frozen, instaead of defrost water going down the tube and under refrig in drain pan, becuse tube is frozen its draining into freezer compartment and eventually spilling out through front of unit. totally defrost unit and behind back wall of freezer youll see a metal trough designed to catch water, in the center (under the ice is gonna be the drain hole, pour boiling water down until it runs freely
Top Kenmore Refrigerators Experts
vince
Johnny 1000
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
