SOURCE: cleaning
turn the fan over. on the back you'll see ten holes around the circumference of the cage. use a torx screwdriver of the proper size and remove them. the front part of the cage will come off. the blades are a press fit over the shaft and locating pin. have someone hold the body and pull off the blade.
SOURCE: Cleaning a 14F0 Honeywell Fan
thank you for using fixya. The blade cage has locks and screws that you can remove from the back. once the cage has been removed, you can remove the blade attached to the motor using a vacuum cleaner or you can remove the blades by undoing the screw on the center detaching it from the motor.
SOURCE: Humming noise from motor of oscillating fan.
Wd-40 is not a very good lubricant. It only lasts fror a few days and then dries up again. In order to get your fan working again, take some 3-in one oil and put a drop at the bearing side of each bearing top and bottom with the shaft upright. Spuin and tap the motor briskly with a small tack hammer or screw driver handle. This will impact and allow the oil to get into the bearings Keep tapping and turning until you feel it lighten up a spin freely. Turn it over and do the same thing again. I garuntee that all will be fine after this.
Testimonial: "Unbelievably fast response - off to try to fix it!"
SOURCE: purchased a new stand fan but after few days
The motor has gone bad... the best thing to do is to take it back and get another one... often if a motor is bad it will fail very quickly like that...
Heatman101
SOURCE: Have a Duracraft DT-70. It
You will need to take this apart and use a good degeasing spray to remove off al the dirt. Use diesel/kerosene to wash well and clean it dry. Use a good paintt brush to wash off all dirt into the hidden areas.
Wipe dry finally to reset.
