I have the same problem need codes to set up tv , a GE brand to my URC-3605B01 remoteI have the same problem need codes to set up tv , a GE brand to my URC-3605B01 remote
Universal remotes with an Input or Source button may work but you will need to search through the codes to find one that matches the feature. The ones that are programmed via a computer (USB) will certainly work. (The codes in a universal remote are often limited to those devices released at least 6 months before the remote was programmed.)
good day remote code apply only when your using the universal remote to match the unit your going to use.when your sony tv remote lost or damage. thats the time you need to use the universal remote and code to match to your tv set
You need to change the dip switches to different codes. Most likely it's a 1-4 small switches. Factory default is usually all on. Just change each fan to different positions and make sure you do the same with the matching remotes. The remotes must match the corresponding fans.
Since there are little specifics given please go to the following site
and match your equpment to discover the answer.This is our Tech Portal
site. Just match your remote to the remotes listed under the remote link and go to program codes for your TV
model.If you need help programming remote go to the receiver link and
match your receiver then go to the manual or user guide to the section
regarding this issue. Thanks for using Fix Ya. http://tech.dishnetwork.com/departmental_content/TechPortal/index.shtml
Since there are little specifics given please go to the following site and match your equpment to discover the answer.This is our Tech Portal site. Just match your remote to the remotes listed under the remote link and go to program codes for your TV model.If you need help programming remote go to the receiver link and match your receiver then go to the manual or user guide to the section regarding this issue. Thanks for using Fix Ya. http://tech.dishnetwork.com/departmental_content/TechPortal/index.shtml
I purchased this same DVD player (DRC282) and none of my universal remotes worked for it. Since I was lucky enough to buy one without a remote, I ended up purchasing an RCA universal remote (RCR3273). Once again, none of the codes worked so I had to unplug the unit for 5 minutes, then plug it back in and hold the Standby button for 15 seconds to return it to it's factory settings. I manually searched through 71 codes before I found a match but the play, pause, rewind and many other functions failed. I tried again skipping over 71 and found the right code at 115 tries. That one had all the functionality I needed. You should try the same strategy with your Comcast universal remote. Skip the first match and keep going until you hit the second manual match.
need acode for rca television
panasonic he-70 volume remote code for sky remote
how codes reciver humax
