Hello
No there is no switch in the motor.Correct voltage is done by hooking up incoming power to a combination of internal wires or contacts.
There should be a wiring diagram on the cover where the hookup is.Or on the outside case of the motor.
The high and low speed doesnt make sence to me.Check the rpm of the motor it should be one rpm continueous.
Unless this is a Hvac motor and not a pool pump motor.Possible you may have been sold the wrong motor.
Usually a pool pump is 115 volts 1 speed and 1 rpm continuos duty.Unless you specify 230 volts.
