It's locked to Network call the You can get the unlock code from Network provider.
You need to specify the Network it locked now also ,country!!Because CDMA Network cannot be Unlocked,also after unlock it you can use with only GSM Network,You cannot use with CDMA Network,GSM network locked Phones can be Unlocked,You can use the unlock code to unlock it from the GSM Network lock,You can get the Unlock code from here
Simpleunlocking.com and unlock it from Network Lock,You can follow the instructions below to unlock it step by step...
Nokia 2700 Classic Unlocking InstructionsWarning :
Do not enter any wrong unlock codes on your Nokia 2700 Classic mobile
phones. If you enter over a certain amount of wrong unlock codes on your
Nokia 2700 Classic mobile phone, your phone may get hard locked and
sometimes become unusable.
1 - Switch on your Nokia 2700 Classic without any sim card.
2 - Don't bother as to what is displayed on your Nokia 2700 Classic.
3 - Compose #pw+CODE+1#.
4 - The Nokia 2700 Classic would then display the message "SIM Restriction Off" and will be unlocked!
Note :For Nokia 2700 Classic mobile phones locked to the network Fido or Rogers in Canada follow these instructions :
3 - Compose #pw+CODE+7#.
The letter p appears if you press the button star(*) three times quickly
The letter w appears if you press the button star(*) four times quickly
The symbol + appears if you press the button star(*) two times quickly
The CODE you need to enter is the unique unlock code for your Nokia 2700 Classic
