Check that the batteries are correctly inserted.
The screen may be too light to see anything.
To darken it
Press [2nd] key and release it.
Press and HOLD [UpArrow] till it darkens enough.
If that does not solve the problem here is what the TI Knowledge base has to say. Please read till the end. I hope it helps.
For the TI-83 Plus Family, TI-84 Plus Family:
Caution:
The resets described in these troubleshooting steps will cause a loss of
applications, programs and data. If at all possible please create a backup using TI Connect™ first.
- Try a new set of AAA batteries.
- Adjustthe contrast by pressing and releasing the [2nd]
key followed by pressing and releasing the up arrow; repeat as
necessary. To adjust or lighten the display, use the down arrow.
- Remove one of the AAA batteries. Press and hold the
[CLEAR] key. While holding [CLEAR],reinsert the AAA battery and then
turn the calculator on. The calculator should display the message "RAM Cleared". Release the [CLEAR] key and then press it one more time to remove the message.
[DEL] key. While holding [DEL], reinsert the AAA battery and then turn
the calculator on. The calculator should display "Waiting...Please install calculator software now". Follow the instructions for the TI83-family or Ti84 Plus family to reinstall the calculator operating system (see below.)
- Remove all of the batteries including the round lithium
battery for 5 minutes.After the 5 minute period, reinsert all of the
batteries and turn the calculator on. Adjust the contrast if necessary.
Reinstalling the OS fot the TI84Plus
How
do I correct the Error
Waiting...Please Install Calculator SoftwareNow
message on my TI-83 Plus family or TI-84 Plus family calculator? If an operating system (OS) update fails or is interrupted, the calculator will be in an inoperable state with the message
Waiting...Please install calculator software now.The
most common cause of a transfer being interrupted is updating
the operating system on a calculator with low batteries. Users will need
to use the TI Connectivity cable and the TI Connect to send
the operating system to the calculator. Make sure to have the
latest version of
TI Connect installed on the computer.
In order to install the software please follow these steps:
1. Connect the TI Connectivity cable between the computer and the calculator.
2. Click on Start >> Programs >> TI Tools >> TI Connect >> TI OSDownloader
3. Follow the on-screen directions to reinstall the calculator's OS.
If the
message "Error! Press any key to turn unit off. Then turn unit back on."
appears on the graphing calculator, quickly, remove one battery from the
calculator and reinstall it while the transfer is taking place.
If that does not solve the problem, you should contact Texas Instruments at
[email protected] or www.ti.com/calc.
