Everything seems ready, but the camera makes a beeping noise and will not take a picture, why?
1. If the camera can not focus on a subject, or can not determine the appropriate exposure setting, the camera will beep and disable the shutter button. This is to avoid improper processing of the image. This is usually due to either poor lighting conditions or movement. 2. The camera Flash Element requires ten seconds to recharge between images. Although the camera is ready to continue capturing images almost immediately in bright (daylight) settings, if you are using Flash photography the Flash element will need to charge between shots. If you try to take a picture before the Flash is charged, the camera will beep and disable the shutter button. Once the Flash unit is fully charged (10 seconds), the camera is ready to continue. 3. The batteries may be running low. LCD Display, Flash, and Playback use much more power than taking pictures. It is possible to quickly consume battery power, even if you are not taking many pictures. Try turning the Mode Dial to the OFF position to recycle power. If the camera beeps and will not take a picture under normal conditions, you may need to change batteries.
