Chaphion tolet
The problem seems to be that the inner column of the flush tower is supposed to grab the outer column, but doesn't. When you flush, the inner column also raises the outer column which is evidently the drain plug. When raised to full height, the outer column drops down and reseals the tank. When you release the lever, the inner column drops down and reengages the outer column and is ready for the next flush.
His problem is that about 80% of the time, the inner column doesn't engage the outer. So you have to trip the lever about 5 to 10 times before it does. Eventually it will.
Hi jeffefam, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? are talking about fill valve, or flush valve. the fill valve is fluid master-readily available, the flush vale is readily available and is replace as unit.https://www.americanstandard-us.com/-/me...Hi jeffefam, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
https://www.americanstandard-us.com/-/media/sites/asus/files/parts/bulk/repairparts2002014.pdf?la=en
You can't post conmments that contain an email address.
Sounds like the inner throttle cable is binding with the outer casing, This coule be caused by dust and moisture causing rust on the inner cable. I would firstly try to get a light spray lubricant into the outer casing . I would disconnect it from the throttle lever and spray lubricant onto the inner cable and progressively work the throttle lever to draw the fluid into the outer case. Elevate the lower end so gravity will assist you.
Open the loading door and place your hand at the top of the inner tub, close to the door opening and lift slightly. Inner and outer tub should move as one solid unit. If there is play between inner and outer tubs, you likely have a tub bearing issue. That is bad news, but repairable if you have the ability to DIY. If the tubs seem good, then look for a sock between the inner and outer tubs. Often it is in the upper left corner (but could be anywhere) close to the door opening so that you can grab it with your hand or needlenose pliers. If you give the tub a spin you may be able to locate it by sight and feel, or with a flashlight from inside the tub through the drain holes. Also look for an object that may be stuck in one of those drain holes, like a screw, etc. Let me know if this is no help, we will look for other causes.
see the causes and fix it. God bless you If your washer won't drain, check these:It spins, but doesn't pump It doesn't spin or pumpIt pumps, but the water returnsIt spins, but doesn't pumpIf
your washer spins but doesn't pump the water out, the drain line is
probably clogged. In many washers, a small sock or other piece of
clothing can get between the clothes tub and the outer tub that holds
the water. If the clothing gets between the tubs, it may then get into
the drain hose that's attached to the pump--or even into the pump
itself. If it's in the pump, you need to remove the hoses from the pump
and pull the item out.To
remove the sock from the outer tub port, open the washer's main access
panel and remove the large-diameter rubber hose that connects the pump
to the bottom of the outer tub. Then, using needle-nose pliers, try to
grab and remove the clothing through the port. Sometimes
you can't remove the stuck clothing from below. Then you have to remove
the agitator, top of the outer drum shield, and inner clothes tub. This
isn't easy to do--and you may need special tools--so you might be
happier getting a qualified appliance repair technician to do the job.If
the drain line isn't plugged, the problem may be with your pump. Even
if the pump appears to be turning, the internal impeller may be broken.
If so, you need to replace the pump.It doesn't spin or pumpIf
your washer doesn't spin or pump water out but the motor is running,
your washer probably has a frozen pump pulley. If so, you need to
replace the pump. To check the pulley, remove the pump from the washer
and try to rotate the pulley manually. If it doesn't turn freely--if
it's frozen or stiff--replace it. It pumps, but the water returnsIf
the water that pumps out of the machine goes back into the machine
after the spin cycle, your washer may be siphoning the water from a
laundry tub that has a slow drain, back into the washer. The usual
remedy for this is to improve the draining of the laundry tub. (Is
something stuck in the drain?) Also, check for these problems:If the drain hose reaches more than about 4 inches into the laundry tub, cut off the excess. If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly.
see the causes and use the common sense, God bless you. If your washer won't drain, check these:It spins, but doesn't pump It doesn't spin or pumpIt pumps, but the water returnsIt spins, but doesn't pumpIf
see the next steps and use the common sense: God bless you It spins, but doesn't pumpIf
Looking a the parts breakdown of the outer tub i dont see a listing for a bearing so i suppose it's a part of the tub. I have included the link for that parts breakdown.
