Samsung SyncMaster 910T 19" LCD Monitor Logo
My Samsung Sync Master 910r keeps flashing "not optimum mode Recommended Mode 1280*1024 60Hz" I have had other monitors connected to this PC and The other PC as well without this error message. How do I fix this? I can't even access my desktop to change the settings?
5 Related Answers
A
Anonymous
  • Posted on Mar 03, 2008
SOURCE: not optimum mode recommended mode 1024 x 768 60hz
change frequency to 85hz
Anonymous
  • Posted on Apr 30, 2009
SOURCE: have a problem with resolutions
sinc ok vga cebul conacting no display
mastertech48
Richard C Cohen
  • 171 Answers
  • Posted on Sep 22, 2009
SOURCE: Synchmaster 913
Hello. That message appears when the video signal from the computer exceeds the monitor's ability to display it. If the sync is set too high(i.e. max sync on the monitor is 60 Hertz at that resolution), you will get that message. Check the video settings in control panel--("appearance and themes" in XP), go to the "advanced" tab and look at the refresh rate. Most computer video cards are able to far exceed a monitor's display ability. Don't exceed 60 Hertz--check the users guide for specs--the lower resolutions can have higher refresh rates(useful in games) Sometimes, a little lower video quality can yield a big performance difference in the display because the screen can update itself faster. (I use a radio control flight simulator pgm that is heavy on video ability).---Hope I was of assistance!---Rick
Anonymous
  • 134 Answers
  • Posted on Dec 06, 2009
SOURCE: Hi
Try to change the desktop display settings, see screenshots below, see if it works
Right click on your destop and go to properties > settings
  1. Set your Screen resolution to 1280X1024
  2. Then click advanced and go to Monitor and set the refresh rate to 60 Hertz.
MalKontent68
Stan
  • 748 Answers
  • Posted on Dec 22, 2009
SOURCE: The unit displays 'Not Optimum Mode 1280 x 1024
Make sure you also set the refresh frequency to 60Hz as suggested. You don't specify what system are you using, but it can generally be found in advanced display preferences under Monitor.
SAMSUNG SYNCMASTER 226BW WHEN TURNING ON MONITOR, IT SHOWS BLACK AND WHITE LINES THEN IT SHOWES A BOX THAT SAYS "NOT OPTIMUM MODE, RECOMMENDED MODE 1680 x1050 60HZ " AND IT IS STUCK ON THIS...
hi dear
start your computer on safe mode and go to the display property change to as per mentioned rresolution on your screen.
best of luck
regards
raj
2answers
My monitor keeps going blank with a window that pops up saying "Not optimum mode. Recommended mode 1280 x 1024 60Hz" then there is a question mark box. I can't get the display back, no matter...
check you video graphic card option and select or fight the right resolution,otherwise update your video card and you can use this :
CLICK ME
here's the serial : JCCQ-MAKC-KACK-6TSE-BN35
I have a Samsung Sync master T220p monitor and i have a problem with games that can not support 1920x1200 resolution. I received this Error : Not optimum mode recommended.
u need to fix the resolution 1020x768 pixel and properly install VGA driver.if u have any problem after that plz install a graphic card on your pc
My computer is on but all I see on the monitor is a floating box with the message "Not Optimum Mode Recommended Mode: 1280X1024 60Hz.
Try connect a different monitor on your computer and change the resolution to 1280x1024. After that, replug the new monitor and it should work.
23helpful
9answers
Same problem not optimum mode recommended mode 1280x1024 60hz
hope this is helpfull http://www.ehow.com/how_4758816_repair-samsung-lcd-monitor.html for me it was
2answers
Samsung Syncmaster 710n monitor - screen goes black for no reason. All cords connected properly. Computer works with other monitors. Switch on front of computer is on - green light on. Get floating...
in safe mode adjust the resolution lower than 1280x1024
then restart and then install the driver again the driver is crrupted than install the right driver problem could be solved
2answers
Not optimum mode 510v 17" LCD Monitor
well, you need to change the EEPROM on the AD board.
6helpful
3answers
Not optimum mode recommended mode 1024 x 768 60hz
Hook up a different monitor and set resolution to no higher than 1024 x 768. Samsung monitor will then work fine. It appears that something fails in the monitor and it will no longer support anything higher than this.
Top Samsung Computers & Internet Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Jean Thiebaux
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
