Dell 1201MP Projector Logo
Anonymous Posted on Aug 08, 2011
I cant hook up my ps3 what cables will i need
Electro Med Services
Level 3:
  • Dell Master 6,694 Answers
  • Posted on Aug 08, 2011
Dell Master
Level 3:
Answers
6694
Questions
Helped
1870192
Points
21433
You can use the VGA input for connecting the PS3. for that you need D-sub to HDTV/Component cable. Connect the vga sid to the projector and the component RCA side to your PS3. Your PS3 have the component video out.
ok
Cant hook up my ps3 to my netgear wgr614 n150
need to get ps3 component cable that can hook directly to the router,if it is a wireless router goto ps3 setup menu,then turn on network discovery on ps3,then will ask for password from router fill password in,it will hook up.
Hi, I hooked up a ps3 to my Daewoo DTQ-27U4SC tv and it wouldn't work. From what I understand, all I do is hook up the power to the ps3 and hook up the RCA cables between the ps3 and tv. I hooked up...
if the ps3 is set to hdmi it will not work threw the av cables. you need to change the settings on the ps3 to use av cable. its mostly set to hdmi as factory setup .
Hd port on back broke need to reset video to use av cables any help???
Press the power on the PS3 for 5 seconds (in standby mode) till it beeps thing to reset the graphics output
I have an lg 50pg20 and i cant hook up my ps3 using the hdmi cabl
Make sure the xbox display settings are not defulted to 480. Have you tried using the component hookup instead? Theres really not that big a difference in quality between the two if your settings are correct in the xbox display menu.
Cant hook ps3 up
Can you explain your problem with a little more detail?
Have you already tried a manual video reset?
Are you using A / V cables?
Ps3 wont hook up to my wire less g router
go to the main screen and check your internet connection settings...
HDMI for PS3 Doesnt work
do you get picture on tube tv if so hook up to tube tv go to settings and set for hdmi then turn off and take to hd tv hook up with hdmi cable and should work you need to set hdmi in settings as it will be set for s-video at 480p I do believe
I need help with my ps3
did you hook the ethernet cable from the modem to mthe back of your ps3(wire internet)
do you have a wireless router(wireless internet)
are you trying to hook it up wire or wireless
Problems getting my ps3 to work with the reciever.
cheak setting in ps3 and use 720 p not all sterios handle 1080 p tranfer best u put ps3 directto tv then optical cable from tv back to sterio on a ch ok
Cant go from a/v cables on my ps3 to hdmi cables! AAAAHHHHHHH
I had the same problem. If you go into the system settings portion of the menu and reset to default settings, then connect your HDMI cable while the system is re-loading, the PS3 should "see" the HDMI cable and ask you if you want to connect your audio and video using that. Hope this helps.
Top Dell Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
Norman Weimar
Norman Weimar
Ngoro
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
