The problem is one(or more) of the 6 switches that turn on the spark when that burner is turned on is shorted and stays closed (on) all the time.To determine which one it is the front face has to be removed,with THE POWER OFF a meter set to low ohms rating is used to check each switch by removing the wires to it and see which one has continunity (ZERO OHMS) when its off and that switch that slips on the burner valve shaft is the bad switch(s) and needs to be replaced to keep it from sparking all the time.
Please note though, in a perfectly working cooktop all burners spaks at the same time and only the only one that has the gas flowing to it will ignite,that part is normal.
I hope this helps you to repair your cooktop,
Gene
