Question about Tilia FoodSaver V3240 verticle vacuum food sealer system
My foodsaver vacuum sealer 3240 jammed and won't
3 Suggested Answers
6ya staff
SOURCE:
Lee Eismann
  • 88 Answers
SOURCE: My foodsaver Vac 420 Vacuum Sealer won't heat and
This is likely happening because the unit cannot detect that a vacuum has formed, and because of this, the unit will not seal the bags, with the gaskets around the vacuum channel being the probable culprit. The Foodsaver gaskets will deform and/or dry out with time, just like in any device, but you don't necessarily have to replace them. I've tried this inexpensive solution on my own Foodsaver V2490, and it works perfectly.
Buy some food-grade silicone grease and apply it to both the upper and lower gaskets. I remove the gaskets and coat both sides with a thin layer of grease before replacing them in their respective channels. And since this grease will be absorbed and/or dry out with time, you will have to do this occasionally, so I also flip the gaskets (i.e. turn them over) whenever I apply the grease.
You can buy a 2 oz container of silicone grease at any dive store, or you can buy it over the Internet by searching for "Trident silicone grease".
This is a link where you can buy it for around $7.00:
Dolphin Dive Center
I do not work at this dive center, but I am a scuba diver and already had some grease that I use for the numerous rubber gaskets in my gear. The 2 oz. jar will last you several years, and you will find many other uses for it around the house since the grease will last longer than a spray.
Posted on Aug 02, 2010
Lee Eismann
  • 88 Answers
SOURCE: Foodsaver Food Sealer Vacuum V2240 T: Foodsaver Professional II Turbo. Vacuum pump work...
This is likely happening because the unit cannot detect that a vacuum has formed, and as a result, the unit never "turns on" the heating element to seal the bag, with the gaskets around the vacuum channel being the probable culprit. The Foodsaver gaskets will deform and/or dry out with time, just like in any device, but you don't necessarily have to replace them. I've tried this inexpensive solution on my own Foodsaver V2490, and it works perfectly.
Dolphin Dive Center
Door to my foodsaver is stuck on one side. It's shut. How can I release it? Is there a release button anywhere?
Trouble with Food Saver Brand - Survival Podcast
thesurvivalpodcast.com > ... > Food Preps > Processing Food For Storage
Aug 15, 2010 - 17 posts - ‎13 authors
We have been using our Food Saver Vacuum sealer we bought ... connects somehow got stuck open and therefore the bags would not ..... I've had the FoodSaver V3840 for about 10 months now and thus far it has been great.Missing: door
FoodSaver Repair - YouTube
? 8:22
https://www.youtube.com/watch?v=jguFiF0Rouw
May 21, 2014 - Uploaded by Kelly Kimble
Repair a FoodSaver that isn't drawing out air anymore. In this case, its ... Vacuum Sealer Troubleshooting - Duration: 10:25. katzcradul 52,345 views. 10:25 ... How to Food Saver Lemon Juice or Other Liquids - Duration: 4:56.
[PDF]Use and Care Manual - Home Depot
Jan 25, 2016 | FoodSaver Vacuum Food Sealer - V3840
2240 unit vacuums but won't go into seal mode. if the seal button is manually pushed, it will then seal but the vacuum is lost
I am having the same problem, it is like the heating element for the sealer is broken.My unit actually will NOT seal if I push the manual seal, but the vacuum works.
Feb 24, 2013 | Tilia FoodSaver V2240
V3840 Food Saver won't vacumn
Hi valkenwil798
Go to the following webpage for parts to repair the vacuum part of the sealer
Please take time to rate me
Bud
http://www.foodsaver.com/parts.aspx?cid=0
Sep 30, 2012 | Tilia FoodSaver V2240
Need foodsaver part bel 5A MQ 125v
Hi Karen Keehn
Go to the following webpage and order your parts you need for your foodsealer.
Bud
Sep 29, 2012 | Tilia Foodsaver V835 Vacuum Sealer
Why there say tray full red light
The tape trick didn't work for me. Had to cut the wires. Works for now.
Sep 27, 2012 | FoodSaver Smart Seal Vacuum Sealer V3825
Is there a manual available for the Tilla Foodsaver Model 115v 50-60 HZ? I've typed it into the search but cannot find anything. I hear the air vacum running and it seems to work for the canister...
Hi hydroped...
I also searched the web...could not come up with the manual
I did a search for a manual at this Tilia's website but was not available for your model V835..
But you could go to the website and look at one that looks close and see its manual.
It might give you the idea that you need to solve your problem
Sep 10, 2011 | Tilia Foodsaver V835 Vacuum Sealer
Doesnt vacuum all the air out
Your Product Manual for the Tilia Foodsaver Food Sealer Vacuum V2240 is available here:
http://www.foodsaver.com/Manuals/MANUALS/T000-32030_44_65900646.PDF
Please review all the Tips for Successful Vacuum Packaging. You may find some pointers that will you remove all the air.
Mar 26, 2011 | Tilia FoodSaver V2240
My Tilia Foodsaver 370 won't turn on. A light
you have to press hard to make it close than it should work
Aug 22, 2009 | Tilia Foodsaver V835 Vacuum Sealer
Tilia FoodSaver V3240 verticle vacuum food sealer system Logo
519 people viewed this question
Top Tilia Kitchen Appliances - Others Experts
Sheldon Dedek
Vitally Alcher
Bonard Allen
Are you a Tilia Kitchen Appliances - Other Expert? Answer questions, earn points and help others
