Kenmore Elite Oasis 27052 Top Load Washer Logo
Anonymous Posted on Aug 07, 2011
How do i open the top of my machine? - Kenmore Elite Oasis 27052 Top Load Washer
Anonymous
Level 3:
  • Master 396 Answers
  • Posted on Aug 08, 2011
Anonymous
Master
Level 3:
Answers
396
Questions
0
Helped
157239
Points
1224
I do not have the correct model number from the manufactures plate located on the washer, so I cannot look at the exploded parts view of you unit. I have indicated the procedure used on most top load washers which may work. You should use caution because it may not be the same style but you may be able to loosen or remove the screws from the back of the hinges to lift the top. If you can give me the correct model number I may be able to look at the diagram to give you more Ideas if this does not work.
You have clips on each side of top cabinet located in the front of the unit. If you pull the top forward and lift up you should be able free the top cover enabling you to lift the top back on its hinges. You may also use a non marring tool (wood or plastic wedge) to pry the top off while pulling the top forward. If it will not lift or you are afraid that you may damage the unit you can loosen or remove the two screws (part 34) for the hinge (part 32) in the back of the unit. You should be able to move the top forward and lift it above the retaining clips. You can replace the hinge screws so you can lift the top back on its hinge so it will not fall off when working on the unit.
Click on the link for a diagram of the parts.
http://c.searspartsdirect.com/lis_png/PLDM/K0702015-00001.png
Remove top lid on Miele novotronic 500 washing machine
Removing the top lid on a Miele Novotronic 500 washing machine will depend on the specific model of your machine. However, here are some general steps that may help:
  1. Unplug the machine from the power supply.
  2. Locate the release catch or lever on the top of the machine. This may be located on the front or back of the machine, depending on the model.
  3. Press or push the release catch or lever to release the top lid. It should then be able to be lifted off.
  4. If you don't find any visible lever or catch, please check the user manual of your washing machine, as some models may have a different mechanism to open the lid.
  5. If the lid is still not opening, it may be stuck due to a malfunction or an error. In this case, it is recommended to contact the manufacturer or a professional technician for assistance.
It is important to be cautious when handling the top lid of the machine, as it can be heavy and fragile. It is also important to make sure the machine is not running or plugged in before attempting to open the top lid.
1helpful
How to remove the top from a Brother Mademoiselle 821 sewing machine
To remove the top cover of your Brother Mademoiselle 821 sewing machine, you will need to follow these steps:
  1. Unplug the machine and make sure it is in the off position.
  2. Locate the knob on the top of the machine. This knob is typically located on the right side of the machine, near the back.
  3. Turn the knob counterclockwise to release the top cover. The cover should pop open.
  4. If the cover does not open, check to make sure that the machine is in the off position and that the knob is turned all the way counterclockwise.
  5. If you are still having trouble opening the top cover, you may want to consult the user manual for your machine. The manual should have specific instructions for removing the top cover, including any combination of dials that need to be switched to a certain spot.
  6. If you do not have a manual, you may be able to find one online by searching for the model number of your machine.
  7. If you are still unable to remove the top cover, you may need to contact Brother customer service or a technician for assistance.
1helpful
The door is not opening
1. the door will not open if in the sanitary cycle.
2. the door will not open if the water level is too high. (open access door at lower left on front of machine and use the hose there to drain water out of washer.
3. the door will not unlock without power to machine except for the following:
4. unplug machine, remove top cover by removing bottom screws from plastic clips on back of washer top, then standing in front of machine, using the palms of your hands to sharply push back the sides of the washer's top about 2 inches, allowing top to be lifted off machine. reach down to door latch and manually move latching arm on door latch to allow door to open.
1helpful
Smart drive9 the machine will not fill and it beeps
Power off the mains,close your wall faucet, unscrew the hoses at the top where the water comes to machine (need not open machine). Check to see if anything is blocking the mesh you see, clean out with old toothbrush, toothpick. Check you faucet, water pressure should be good, use bucket. Refit carefully without cross threading, check for leaks. If it still does not work, open top of machine to check wiring harness at inlet valve. No work? change inlet valve, you can do it yourself.
To open top, remove 2 or 3 screws behind top of machine, the top shd slide away an inch or so backwards, then lift off.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Try these sites for spares:
RepairClinic.com
espares.co.uk
AppliancePartsPros.com
mcminone.com
How abt rating me 'very helpful' for the free help, thnks
If we open the lid of the top load machine at the spin time?there will any problem for the machine
All top load machines have a braking system to stop them spinning when the lid is opened.. Most have a mechanical system which, although sometimes noisy, does not damage the machine.....However, direct drive machines like fisher & paykel may have an electronic system which converts the motor to a generator, which slows the spin....The generated power in this type of machine can cause damage and the lid should never be lifted while the machine is spinning.....Check with your brand's service agent... Good luck....Nomess
3helpful
How do I open the machine to clean the metal bin
To open machine take two flat head screwdriver and gently insert them in top of front panel about 3 to 4 inches from side and push in to get clips to compress and lift top panel of machine. This will give you access from top side. If you need more room there are two screws, one on each side of front panel, remove and pull panel forward and up. Reinstall in like manner.
The lid on my top loading admiral mega 22 plus washing machion is
These are plastic and will need to be replaced with new.
Once you have sourced new hinges then the machine top needs to be opened,
Electrically Isolate the machine, then at the joint between the machine front panel and top insert a flat blade 4" from each side to release the lid catches, tilt back the top to access the screws on the hinges and replace with new.
How do you open the top of a front load washer?
most have a few screws at the back of the machine holding the top in place.....once you have taken the screws out, slide the top forward....please make sure you unplug the machine prior to opening it up
Calypso 22066 top=load washer
You probably have hoses and sump pump plugged/jammed by not enough to the machine from operating, my machine leaked prior to cleaning out all the hoses and sump pump
Alexander
vince
