D-Link DIR-450 Router (DIR450) Logo
Posted on Sep 03, 2008
D-Link Dir 450 configuration problem
I have a Dir 450 that keeps resetting to the default modem type with in 5 min after I set it up. I am using the Sprint Novatel Ovation U720. I have used this router for about a year before I started having problems. I have tried to reset this many times and every time it resets to the default modem within a few min. I have the firmware up to date.
Anonymous
Level 1:
  • Contributor 35 Answers
  • Posted on Sep 04, 2008
Anonymous
Contributor
Level 1:
Answers
35
Questions
Helped
10280
Points
41
It seems like the routers firmware might be corrupted what you can do to solve these problem is basically upload the same firmware and check to see if solves problem.If not you might want to contact Dlink for further support even possibly a replacement if hardware is bad.
Wireless modem
If the default password on the D-Link has been changed then-
To reset the D-Link back to the default settings -
Press and hold the RESET button at the back of the router with the power ONuntil the LEDs flash at the time the release the RESET button. (firmware version was 3.00, and upgraded to3.05)Connect a LAN cable from the D-Link to your laptop/computer'sLAN port, open the browser on your laptop/computer and enter the D-Link's configurationURL..
http://192.168.0.1
The default login = admin
The default PW = blank (just press Enter)You can now change the default admin password.
You can now configure the wireless settings. Now configure the wireless card in your computer/laptop withthe router's wireless settings.To secure your wireless network from unauthorized access,please click on this link and follow my instructions :-http://www.fixya.com/support/r3559128-wireless_router_security
1helpful
I don't know how to reset password for d-link DIR-625
Section 1 - Product OverviewHardware OverviewConnectionsUSB Connect a USB 1.1 or 2.0 flash drive to configure the wireless settings using WCN.Reset Pressing the Reset button restores the router to its original factory default settings.LAN Ports (1-4) Connect Ethernet devices such as computers, switches, and hubs.Internet Port The auto MDI/MDIX Internet port is the connection for the Ethernet cable to the cable or DSL modem.Power Receptor Receptor for the supplied power adapter.D-Link DIR-65 User Manual
If you don't know it you can check our list of default router and modem password list here.
If you have changed it and don't remember it you may have to reset your device to factory default using the reset button on most routers.
Ever since the storm I can't get online wirelessly, I can't get on with the internet cable direct but not with the dlink 600. Please help.
check
1.- Cable leave modem is attached to Port WAN (they are others 4 ports LAN)
2.- In router Dlink DIR 600 led Internet in On or blinkling
3. using web browser type http://192.168.0.1 (this is IP default )
4.- reset your DIR600, using a clip press in reset Hole 10 seconds
5. Try again using web browser type http://192.168.0.1
If connect, re configure your modem for your wireless network
2answers
I lost my manual and i wrote my passkey on it then i can't remember now so how can i change my passkey to connect in wi-fi router using my modem dlink 600
If the default password has been changed then -
Connect a LAN cable from the D-Link to your laptop/computer's LAN port, openthe browser on your laptop/computer and enter the D-Link's configuration URL..
http://192.168.0.1
The default PW = blank (just press Enter) You can now change the default password.
To secure your wireless network from unauthorized access,please click on this link and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
We changed the username and password to connect t wifi now we cant remember it how can solve this please
Reset your modem. This modem have one reset button .Press the button for 30 Second.
Then follow the procedure .
Default IP address : 192.168.0.1
Default user id : admin
Default password : Don't enter anything keep it blank.
After doing this configure your router for internet setting.
Thanks for using FixYa.
Cannot connect to wireless internet
How did you reset the wireless router back to the factory defaults?
Did you use the Reset button on the back of the D-Link?
The encryption setting is set in the router's wireless configuration.
After the router has been set to the factory default, connect a LAN cable to the wireless router and open IE browser and enter the configuration IP address (http://192.168.0.1) the default login = admin and the PW = blank (just press enter)
Then change to default password so it prevents anyone changing the router's wireless configuration.
The encryption default should be not be enabled.
Change the SSID so you and your guests can identify your wireless router.
You can enable encryption if you wish to prevent unauthorized access, but you need to advise your guests of the encryption key.
2helpful
2answers
Hi I cant configure my router D-link DIR-300
Hi! I will be more than glad to assist u in this concern..Please dont use the setup cd or setup wizard. you can access the setup page of the router by typing at the url:192.168.0.1 then it will ask for the user name and password, by default the username is admin and the password, leave it blank.. here are the things u need to check before u setup u router.. .. if you are using a cable modem from ur cable company provider- u need to do a mac clone on the router u have to clone the mac address of ur computer. normaly the mac of ur computer is the one register to your cable company and on the setup page of the router just selct on the internet setup, dhcp after clonning the mac address of your computer. u need to connect ur computer directly to the router and then after doing the process connect the router to the modem. if u are using a username and password, u have to use the pppoe settings on the router, if ur isp set a static ip , set it up to the router, to check the ip setting of your isp.. connect the computer directly to the modem and check if u have internet.. then click on start, run and type cmd,it will give u a dos prompt and from there type ipconfig/all and it will show u the ip address, subnetmask, default gateway, dns server.. I hope this will solve ur concern..
1helpful
My DIR-655 won't work!
It would be helpful if you could be a bit more specific regarding the way you hooked up the dir 655 to your network and your specifc DSL modem. If the modem you are using is the Actiontec M1000 DSL modem you will not be able to obtain internet access because the DIR 655 is trying to route an already routed IP, the M1000 has a built in router / DHCP that by default is enabled. You can use option 1, access the configuration settings of your M1000 and change the WAN configuration to act as a transparent bridge. After doing so and rebooting the modem you will have to enter your DSL login information like a PPPoE username and password for example into your DIR 655 network settings. With this configuration the modem simply acts as a bridge to relay data directly to the DIR 655 and the 655 itself provides login credentials to obtain internet from your DSL provider as well as hand out IP addresses to the local network. Option 2 is to continue to use the M1000 as a router by default and disable DHCP on your DIR 655 so that it essentially acts as nothing more than a switch or wireless access point while the M1000 hands out local IP addresses. I personally would recommend using the DIR 655 to route IP's as it's got far more configuration utilities than the M1000 does as a router, and really what's the point of getting the 655 if you're only going to use it as a switch or access point when there are other simpler and cheaper devices that could do that for you.
Does it work verizon wireless un175 usb on dir-450?>
yes...you must change the D Link IP address and disable the DHCP server...use the IP add within the range of verizon dhcp server..192.168.1.1 is your verizons IP..to chANGE your di link IP connect to Dlink wired and not connected to any routers...type 192.168.1.1 to access configuration menu and you can change the setting
6answers
D-link DIR-635 router
Hi, I am assuming that you can connect to your router's web based interface (192.168.0.1). On a PC LAN wired to the router, open a browser; Type "192.168.0.1"; Log-in username/admin and password/(blank); Go to Tools > Misc and the option to select the WAN speed (bottom); Lock the speed down on the WAN port of your router to 10Mbps (Some versions do not have this feature). Hope this works for you. If not pls post back with your modem brand/model. You may also want to log the IP settings (IP Add, Subnet Mask, Default Gateway, DNS Servers) of the PC that is directly connected to the modem when you can access the Internet when not using the router. Good luck and kind regards.
Top D-Link Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Grand Canyon Tech
Grand Canyon Tech
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
