SOURCE: some of the key pad doesn't work any more
The contacts on the electronic board inside the oven for the display need to be cleaned. You should be able to get into the microwave from the back and unscrew the board. One side of the board will have a row of contacts that can be cleaned using first rubbing with an ink eraser and then with a q tip dipped in isopropanol (rubbing alcohol).
I lost all contact with the display on my microwave and this really helped get the key functions back.
Neil
SOURCE: keypad does not respond
try to replace the keypad.and resolder the connection going to board.
SOURCE: Maytag microwave suddenly died after 20 seconds of
Replacr the internal fuse you will find when you remove the cabinet. It will be near where the cord enters the cabinet. It is a special fuse ... get a replacement at most hardware of appliance parts stores.
SOURCE: Whirlpool GT4185SKB-1 Built in Microwave
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
