Beep codes are used by the BIOS during the POST to report certain initial system errors.
If
you're hearing beep codes after you turn your computer on, it typically
means that the system has encountered some kind of problem before it
was able to display any kind of error information on the monitor.
Follow the steps below to determine what system problem the beep code is representing.
Difficulty: Average
Time Required: Anywhere from 10 minutes to a few hours depending on the cause of the beep code
Here's How:
Restart your computer if you need to hear the beeping again. You're
not likely to make whatever problem you have worse by restarting a few
times.
Important: Pay close attention to the number of beeps, if the
beeps are long or short and if the beeping repeats or not. There is a
big difference between a "beep-beep-beep" beep code and a "beep-beep"
beep code.
This is all important information that will help determine what issue the beep codes are representing.
Choose the correct beep code troubleshooting guide below based on your motherboard's BIOS manufacturer:
Tip: Not sure what brand of BIOS is on your motherboard? See this How to Determine Your Motherboard BIOS Manufacturer guide for some helpful advice.
