SOURCE: coil piston
If you purchased it as a package the right piston may already be installed in the indoor Evaporator coil. When shipped the extra piston if needed is packaged with the outdoor section condensing unit.
SOURCE: need recommended sub-cooling and superheat for
Superheat should be 8 to 12 degree's. Sub cooling around 18-22. I like to use superheat that way I know the coil is doing all it can do.
SOURCE: I have a 5,200 BTU Maytag window AC. The fan will
Hi Tom, The capacitor for the compressor and fan is behind the control panel. The capacitor has 3 terminals one terminal is common one terminal is for the compressor and one terminal is for the fan motor. If your just getting a hum / buzzing sound most likely the fan motor part of the capacitor has failed.
I am using this model number for a parts reference: M7X05F2A
Part numbers for the capacitor are: CRC160500710961 and 160500710961 ($34.10 most sites)
The part can be found here:
http://www.appliancefactoryparts.com/search/partinfo.php?partsID=281318&modelsID=&typeName=air%20conditioner
If you do a capacitor change... with the unit unplugged ground all of the terminals to C and then move the wires ONE at a time from OLD to NEW capacitors.
To test the capacitor you probe C to another terminal.. reverse the leads and probe again. You looking for a very brief jump in resistance and then the meter drifts to infinity. None of the terminals should read continuity to the case of the capacitor.
This should get you going unless the blower motor has failed (I doubt that it has)
Thanks for choosing FixYa,
Kelly
I have a fedders 5200 btu ac fan will not run it will humm went trun it on but will not run
