Hi
Error code FH appears when No water is detected
entering machine or Pressure switch trip is not detected. If after 30 seconds
the control does not detect water entering machine and then valves will be
turned off and the error code will be displayed. Press PAUSE/CANCEL twice to
clear the display. If there is no water entering the unit then make sure that
the inlet valves are working fine. You may need to check the continuity at the
inlet valves. If the valves are fine then check whether inlet water hoses as
they might be plugged. Also check for inlet water screen at the valve. However,
if the water is entering into the washer then the Drain pump might not be
working. Also inspect the Pressure Switch hose whether it is in good condition
and properly connected to Tub and Pressure switch. Also check hoses for leak
and inspect the flow meter. Hope this helps...
Daniel
Hi
Daniel
Hi
entering machine or Pressure switch trip is not detected. You may need to check the continuity at the
Daniel
Thank you for contacting fixya.com.
FH
error code means low water inflow. In this error washer is not filling when the
fill valve opens.
To clear the error please follow the bellow instructions:-
Press the "Stop" button twice with your finger. This cancels the
cycle and stops the washer. Unplug the power cord from the wall outlet.Turn the
water shut off valves clockwise to stop the water flow to the washer through
the supply hoses. Pull the washer away from the wall enough that you can access
the hose connections at the back of the washer.
Set
a bucket under the area of the hose connections. Unscrew the hose connections
from the back of the washer. If necessary, use a pair of slip joint pliers to
help start the connections turning until you can turn them by hand. Set the
ends of the hoses inside the bucket.Inspect the screens on the inlet ports on
the back of the washer where the hoses connect. Sediment and other debris can
block these screens, causing fill problems. Clean the screen with an old
toothbrush.
Thread
the hoses back onto the washer. Look for kinks in the hoses. Kinks cut off
water supply to the washer which causes the FH error code. Once you connect the
hoses, turn the water supply valves counter-clockwise to supply water to the
washer. Move the bucket away from the washer and push the washer back into its
working position.Plug the power cord back into the outlet and start the wash
cycle again. If the FH error code comes up again, call a service repairman. If
the hoses have no kinks and the inlet screens are clean, there is a problem
with either the pressure switch or the flow meter.
Please get back to us if
you have further query else please accept the suggestion.
Hello &
Welcome to FixYa
FH error is displayed when the control detects no
water entering the machine. To clear this error press and hold the PAUSE/CANCEL
button twice. You can then check if the water inlet valve is fine and not
clogged with foreign particles, try to clean it. If the water inlet valve
appears to be fine then check if the pressure switch hose is properly connected
to the pressure switch & tub. Please get back to me if you have any
questions.
Kevin
Look for the "Pause/Cancel" button on the washer control panel. The button will be below the digital time clock and to the lower right of the wash cycle selector.
Press the "Pause/Cancel" button twice to cancel the wash cycle. Unplug the Kenmore Elite washer from the wall outlet.
Check for kinks in the water supply hose while the washer does not have power. Turn off the water supply spigots and remove the hoses from the back of the washer. Check the port screens at the hose connections for sediment buildup and clean as necessary.
Connect the water supply hoses back to the washer and turn on the water spigots. Plug the washer cord back into the wall outlet.
Select the wash cycle and press the "Start" button.
If the error code come back you will probably have to change the water inlet valves. No hard to do and you can fdo this yourself
