Dosn't the router come with cables? Connect one computer to the router and see if it works.
If the router is brand new and hasn't been set up yet, it may have open wi-fi working right out of the box without needing a password. In that case, you could use a computer or tablet that has wi-fi, and no need for an ethernet cable.
SOURCE: wireless router G WRT54 V8 cisco systems light is not on any more
Had the same problem -- hold the reset button (on the back next to the ports) in for 30 seconds while on and then pull the power plug and wait 30 seconds before replugging --- it should completely reset and you will have to redo your settings but you won't have to buy a new router atleast..
SOURCE: Just hooked up Comcast internet
SOURCE: Cannot connect in any way to router, all lights on.
access your router's web-based configuration page at http://192.168.1.1
SOURCE: Linksys Router lights just flashing
Try doing a hard reset for 1 minute (longer) then powercycle... there should be a miracle* :)
SOURCE: power light is dim and the 4 ethernet connection
I found this somewhere else but can't find it now - my router got hit by a power surge - i held in the reset button for 60 seconds with the power connected and it sluggishly decided to come back to life. WRT300n V1.1 - your results may vary.
