The incoming cable should simply connect to the antenna/cable connector on the back of the TV. It's a standard connector. Normally you just need to connect the cable to the TV, then set the TV for "cable" through the on-screen menu using the TV remote or front panel buttons. However, the tuner in the TV may not be compatible with your cable system. Depending on the age of the set and type of cable system, the set may only work if you use a cable converter box from the company. If you have the cable connected and the set can't find any channels, this may be why.
