Hazard flasher Flasher is located: Front seating area, driver side, under dash, mounted on driver side of steering column Turn signal Flasher is located: Front seating area, driver side, under dash, mounted on passenger side of steering column
1986 Mercury Grand Marquis 5.0L FI 8cyl. the Flasher is located in front seating area, driver side, under dash, driver side of steering column, mounted in fuse panel (turn signal) and front seating area, driver side, under dash, driver side of steering column, mounted in rear of fuse block (Hazard flasher).
fuses box is eather in the glove box or under the dash on the driver side and at the end of the dash on the driver side by the door. It could be a bad motor
One fuse box is located under the hood on the driver's side. the other is located on the driver's side of the cab, open the driver's door and on the side of the dash there is a door to open to reveal the fuses there.
