No, Its sounds like you have a receiver tank check valve bad. This valve is designed to hold pressure in the tank . there should be a line on the side of the check valve that goes to the pressure switch. This allows air trapped from the top of the check valve to the compressor to escape so when the compressor starts it does not have to start against pressure in the system. Loosen the line at the check valve or the pressure switch. if it blows until the unit starts or drains the receiver tank if not powered up replace the receiver tank check valve.
