SOURCE: microsoft lifecam 1000
You can download the driver here :- http://www.opendrivers.com/driver/236296/microsoft-lifecam-nx-6000-vx-1000-vx-3000-vx-6000-driver-1.21-windows-xp-free-download.html
the camera has a built in microphone,so after a proper installation you should have the video and mic funtioning.
but in your case, the cam doesn't work, so you have to try first uninstall the driver >> unplug the camera USB port >> then make a restart >> plud the camera back into the usb >> and install the drivers again.
SOURCE: Microsoft lifecam VX-6000 - no Video
your cam has to be setup with the messaging programs have you tried that
and does your cam show in device manager
SOURCE: I cannot adjust the audio on lifecam vx 3000.
Normal
0
See section C. Windows Live
Messenger in the info below to setup the Audio & Video.
Web Camera’s have to be
setup on the program they are to be used with.
Just installing the camera on your computer does not set it up to
broadcast on messengers or Skype.
Each program has Options that have to be setup in order for
the Audio and Video to function properly.
A. Skype Setup:
After downloading and installing Skype (http://www.skype.com/intl/en-gb/download/skype/windows/beta/downloading/Bud )
The camera and audio should function properly. Your friends and Family will now be able to
see and her to you.
C. Windows Live
Messenger:
Go to this
site http://download.live.com/?sku=messengerBud and download Windows Live Messenger.
NOTE: Your audio and
video should work. Enjoy.
When done both the Audio and Video will function properly so
you can chat and see family or friends you are connected to.
Hope
this helps. Bud
SOURCE: blue screen appears when I instal Microsoft nx-6000 cam
uninstall the Cam software.restart the system Click>start>run>type verifier>ok >u will get a window for Microsoft Driver Verifier click next twice (it will search for Unsign Drivers)if any Click next restart.Now install ur Cam Software it shouldwork.
SOURCE: Microsoft Lifecam / Using a different microphone
Im not sure I understood exactly the issue but the solutions are more than one ...
you may just uninstall the web cam ...and set the mic you want to use and after that reinstall the web cam ...and you have every chances to be installed and the external mic to remain in use..
or ...to use the mic from the external pink entry of the pc ...just select it from the sound driver ...options..
in your capture program you might also have the choice for which mic to use ....
in your yahoo messenger for example you have this choice on preferences /audio device....
you also may find on your control panel ...sound and audio device /audio../and for the sound recording audio device ...select the one you want...
good luck !
