Steel tip darts are mostly used with bristledartboards. Steel tip darts have a very sharp steel point to stick in the fiberof a bristle board. Soft tip darts are mostly used with electronic dart boards.Soft tip darts have a flexible, plastic tip on the end to easily lodge into theholes on electronic dartboards. I prefer the soft tip because it's usuallylighter than steel tip darts.
I am assuming that you installed a new tip. Note, the tip ends have to be 3/8 of an inch 90 degree bend so that when you insert the tip leads into the barrels, they go into the small holes in the barrels. Also note, the nuts to tighten the tip into the gun have to be installed onto the tip leads before bending the leads. Now when the tip is installed this way, the nuts tighten and hold the tip in the barrel. This tightening of the nuts allow the tip to have a good electrical connection to the barrels and this is what allows the tip to heat. You actually have an electrical current that passes through the barrels and the tip. It is a very low voltage (around 2) but a very high current. Over time the tip will not heat, this is a sign to either tighten the nuts, or look at the tip to see if it has a break in it. If it has an open, then it is time to change the tip.
Style: Flat with ribs Installation Tips: Ribs face toward drum Diagram B Style: Flat with ribs Installation Tips: Ribs face toward drum Diagram C Style: Flat with ribs Installation Tips: Ribs face toward drum Diagram D Style: Flat with ribs Installation Tips: Ribs against drum Diagram E Style: Flat with ribs Installation Tips: Flat side of belt against drum Diagram F Style: Flat with ribs Installation Tips: Ribs against drum Diagram G Style: Flat belt Installation Tips: Side of belt with words faces away from drum Diagram H Style: Flat with ribs Installation Tips: Ribs against drum Diagram J Style: Flat with ribs Installation Tips: Ribs against drum Diagram K Style: Flat with ribs Installation Tips: Ribs against drum Diagram L Style: Flat with ribs Installation Tips: Ribs against drum Diagram M Style: Flat with ribs Installation Tips: Ribs against
