Tip & How-To about Boating
Outboard motors
Keep the gas in your outboard new/clean with new oil every 6 months..Keep your motor covered when not in use, Dirt dabbers (dobbers) will build nest under the hood and break loose and ruin your motor, ,,Change your water pump and thermostate every year when motor is used a lot.....Dont run stainless steel props on small hp motors ,when you hit a log it will bend your prop shaft costing big $$$ to replace..Ck your lower gear oil if water is noted ,replace lower seals...Dont buy used motors unless you run a compression ck....ck for water in gear case , Dont buy 4 strokes to heavy to slow to many parts AND are being replaced by fuel injection 2 strokes .... Dont buy FORCE motors not made by mercury no parts being made and or extink and pure junk . Etex best motors , .
Boating Logo
My weedeater 150 mph starts hard and barely runs at full throttle. I put in new gas, plug, and clean air filter. Please help. John
One cause of such a symptom could be an obstructed exhaust. Make sure the outlet of the muffler is not obstructed (ex. dirt dobber nest), also check the exhaust port by removing the muffler.
Feb 16, 2011 | Weedeater Featherlite Blower 18 Cc 150 Mph...
My Car sat for a couple years and after I got a tune up the car keeps dying out and have to keep my foot on the gas to keep it started
check and make sure that nothing has built a nest in the air intake both before or after the air filter. also i know here in tn. if a vehicle sits for an extended amount of time dirt dobbers build nest everywhere it could be possible one could have built a nest in the throttle body not allowing air to pass through the iac valve. i would also check fuel pressure if there appears to be no blockage in the air intake
Aug 07, 2010 | 1990 Oldsmobile Cutlass Supreme Conv
dirt dobbers building nest car airconditioner blocking water from escaping. Know anything I can use to discourage the little buggers. This has happened twice in three months
You could try cutting the hose back and use a kitchen grade metal mesh food strainer and RTV the top to the fire wall. Cut the metal handle off if you need to. That will keep them out of the hose and allow the water to flow out. A strainer about 3 to 5 inch diameter should do.
Aug 21, 2009 | 1998 Ford Escort
971 people viewed this tip
Top Boating Experts
ray gallant
ray gallant
Andrew Taylor
Andrew Taylor
Tom Chichester
Are you a Boating Expert? Answer questions, earn points and help others
