Tip & How-To about Computers & Internet
Before setting up file sharing
The first time you connect to a network, you'll be asked if you want to turn on sharing between PCs and connect to network devices such as printers. Your answer automatically sets the appropriate firewall and security settings for the type of network that you connected to. You can turn sharing on or off at any time.
Press and hold or right-click the network you're connected to, then tap or click Turn sharing on or off.
Menu used to turn sharing on or off
Do one of the following:
Choose Yes, turn on sharing and connect to devices for home or small office networks, or when you know and trust the people and devices on the network. This setting allows your PC to connect to devices on the network, such as printers.
Choose No, don't turn on sharing or connect to devices for networks in public places (such as coffee shops or airports), or when you don't know or trust the people and devices on the network.
Turning sharing on prepares your PC for sharing files and devices on a network. For more information about sharing with other people on your network, see Sharing files and folders on a network or a shared PC.
The network sharing setting is only available for WiFi, Ethernet, VPN (non-domain) and dial-up (non-domain) connections. It's unavailable for domain networks. On VPN or dial-up connections, you must connect to the network first, then press and hold or right-click the network name to change the network sharing setting.
Turning on sharing changes your firewall settings to allow some communication, which can be a security risk. If you know you won't need to share files or printers, the safest choice is No, don't share or connect to devices.
Choosing No, don't turn on sharing or connect to devices blocks the following applications and services from working: PlayTo, file sharing, network discovery and automatic setup of network devices.
Network discovery is a setting that affects whether your computer can see (find) other computers and devices on the network and whether other computers on the network can see your computer. It's one of several settings that are turned on when you turn on network sharing. You can turn network discovery on or off independently of network sharing, but we discourage this. Here's why. If you're connected to a network in a public location and you decide to turn on network discovery but leave network sharing turned off, the network discovery setting will be on for every public network you connect to from then on. This wouldn't be safe. That's why we recommend using the network sharing setting instead.
However, if for some reason you need to turn network discovery on or off independently of the network sharing setting, here's how to do it:
Tap or click Turn on network discovery or Turn off network discovery, then click Save changes. You might be asked for an admin password or to confirm your choice.
If you have your own internet connection, the next probable cause is a
router. Placing restrictions on some IP address or net services may have
accidentally include your ps3 in it. You can change some settings
within the router to grant your ps3 full access online, while at the
same time maintaining other restrictions that are already in place.
Another possible remedy is have your pc internet connection shared, and
use your ps3 to use that shared connection to go online. These solutions
are sure fire methods of keeping ps3 80028e02 away from your console.
reference: http://www.dtheatre.com/read.php?sid=5603
