Tip & How-To about Toshiba Portege M200 Tablet PC
This should apply to other brands and models...
the original problem: bad hard disk, need to restore from win 7 image disks however The portage m200 lacks an optical drive and cannot be booted from usb (only options are to boot from LAN or from a specially created SD card).
Solution:
you will need a second pc that can boot from an on board or peripheral optical drive. Swap the second pc's hard drive for the one that you are restoring. Now boot the second pc from the restore disk and follow the onscreen instructions. Once completed the pc will try to reboot and you will get an error about how windows couldn't repair start-up. Now power down and swap the hard drive back to the portage. You should now be up and running, much easier than trying to create a boot-able sd image or boot from a PXE server.
