Tip & How-To about Sharp AR-M355N Copier
It's very easy to mistake where and how to replace toner on this unit. It's often assumed that Area 1 is where the toner is. This is actually the Developer Housing. If the developer unit is pulled completely from the copier, its weight will often surprise the user and they drop it on the floor, or worse, dump out the developer believing that it's waste toner. The correct area for the toner cartridge is Area 2. Area 1 is used only to lower the developer unit and unlock it from the toner cartridge, so that the cartridge, itself, can then be removed freely from the copier. If the developer unit is mistakenly pulled and dropped or dumped, a service call will usually be required to recharge the developer unit.
