Tip & How-To about Microsoft Windows XP Professional
Some times even when the Windows Defender service is set to automatic you still might see the Error below and even when you have tried this site http://support.microsoft.com/kb/931849 which tells you to remove the program and then use the windows installer cleanup utility form HERE and start again you still get the same error
This is a method is bit drastic I suggest that first you update manually the definitions from HERE then download my Windows Defender FIX from my Public SKYDRIVE then restart you PC it should now fix the above error it will re-register all the DLLs that are needed to allow the error to go
