Tip & How-To about Dryers
Dryer Cord and Wiring Dryer 3 Wire or 4 Wire
If you have an electric dryer and need to change the style of cord that you have on the dryer on if you just need to install a cord on a new dryer, you may have questions about where the wires need to go. This tip will help you to figure these questions out.
Remember to ALWAYS make sure that all power is disconnected BEFORE beginning your work!!
On the back of your dryer will be a cover plate that will have the wiring connection lugs behind it. A screw or two will need to be removed to expose the connection point. Always remember to reinstall the cover after you have finished your connections.
If you have a 3 wire cord the plug will look like this.
You will have a red wire, a white wire, and a black wire, on the other end from the plug.
The black and red wires will go on the two ends to the matching colors. The white wire will go in the center. If you have a bonding strap make sure that you jumper that from the center lug to the frame of the dryer. If you do not have a bonding strap, then make sure to make one out of #10 ga. wire and a couple of crimp rings. Green wire is preferable.
The connection will look something like this.
If you have a 4 wire cord the plug will look like this
Here again, you will have the red, white, and black wires. This cord will also have a green wire. This wire gets connected directly to the frame of the dryer. With this cord, you do not need the bonding strap or wire. If you are converting from a 3 wire to a 4 wire then remove the old bonding strap if there is one there.
This connection will look something like this.
When converting from a 3 wire to a 4 wire you just REMOVE the bonding strap or wire and hook the green wire to the frame. If you are converting from a 4 wire to a 3 wire then you ADD the bonding strap or wire. It gets hooked from the center lug to the frame.
Always make sure that the outlet that you are plugging into is wire correctly also. The black and red are each 110 volt legs that have a voltage of 220 volts across them. The black and the red wires need to be wired to a double pole 30 amp. circuit breaker. The wiring needs to be a minimum of 10 ga. wire. The white or neutral wire goes to the neutral bar in the power panel and the green wire goes to the ground bar in the power panel.
By following this tip you should be able to hookup a new dryer or convert your existing dryer cord. Recheck all your connections before turning the power back on to the dryer.
http://www.fixya.com/support/r4312805-dryer_maintenance
http://www.fixya.com/support/r3866744-dryer_not_working_dryer_not_drying
http://www.fixya.com/support/r3907570-buy_appliance_parts_online
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
http://www.fixya.com/support/r4496386-dryer_cord_wiring_dryer_3_wire_or_4_wire
http://www.fixya.com/support/r4416566-dryer_repair_squeaks_grinding_clicking
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
Dryers Logo
changing dryer plug
These two pictures illustrate the power wiring on a the terminal of an electric dryer. The one on top is the old-style three-wire configuration. Most people have this type in their homes. New code changes, though, require that dryers now have a four-wire cord, shown on the bottom.
Besides the number of wires in each cord, there are two important things to notice. First, in the four-wire configuration, notice that the dryer's grounding strap is folded back on itself. The whole point of the four-wire cord is to separate the ground from the neutral. The green wire (the "new" extra wire in the four-wire cord) is attached to the dryer cabinet. In the three-wire configuration, the grounding strap is left intact and the neutral and ground are tied together.
Sure hope this helps you find a resolution to your delimma! Best wishes.
Oct 07, 2009 | Amana NDE2335AY Electric Dryer
Changing dryer plugs
Sep 09, 2009 | GE DCVH515GF Gas Dryer
changing from a 3 prong to a four prong
grasshopper_2.gifWiring in a new power cord for your electric dryer? Upgrading your electric dryer outlet from the old three-prong to the new four-prong outlet? Well, grab hold of those two large lumps at the base of your spinal cord and let's romp through the wild and wacky world of dryer cords and outlets.
tn_3cord_dryer_terminal.jpgtn_4cord_dryer_terminal.jpgThese two pictures illustrate the power wiring on a the terminal of an electric dryer. The one to the left here is the old-style three-wire configuration. Most people have this type in their homes. New code changes, though, require that dryers now have a four-wire cord, shown to the right. These are just just thumbnail pictures that you can click for a larger view. But I'll bet you already figured that out, didn't you?
tn_3prong_dryer_outlet.jpgtn_4prong_dryer_outlet.jpgIf you need to re-wire the outlet, these pictures will explain the anatomy of the three-prong (left) and four-prong (right) outlets. Once again, these pictures are just thumbnails--click 'em for a larger view.
Jul 23, 2009 | Dryers
dryer cord
its safer to change the outlet to the new style!
Jun 30, 2009 | Kenmore 62602 Electric Dryer
whirlpool gas dryer turns on drum spins exhaust is clear and blows air but it wont ignite
  1. Changing from 3 to 4 wire hookup on a electric dryer
  2. Door switch replacement help for a common door switch
  3. Dryer basics - Venting problems and power supply
  4. Dryer basics - timers and how they work
  5. Dryer basics - power cord problems
  6. Dryer basics - dead dryer
  7. Dryer *general* repair flow chart....Click here
  8. Gas dryer smell
  9. How do dryer thermostats work?
  10. How long can my dryer vent be in length?
  11. How to change a common rear drum seal
  12. How the belt is suppose to look at the motor and idler pulley
  13. Help on replacing dryer motor  and some wiring tips for the 279827 motor
  14. Help on replacing dryer motor  and some wiring tips for the 279787 motor new25.gif
  15. Help for storing an appliance
  16. Important Disclaimer
  17. I dropped something down the lint filter area....help!
  18. Inglis, Whirlpool and Kenmore most common style dryer - how to take apart ( lint filter on top )
  19. Inglis, Whirlpool and Kenmore most common style dryer - how to take apartslide show ( lint filter on top )
  20. Whirlpool or Sears dryer with heater on the floor and four rollers for drum style - take apart helps ( lint filter in the door )
  21. Inglis, Whirlpool and Kenmore electric style dryers - no heat problems
  22. Inglis, Whirlpool and Kenmore electric element changing procedures
  23. Inglis, Whirlpool and Kenmore dryers - air flow
  24. Inglis, Whirlpool and Kenmore style dryers - noise problems....drum rollers and idler pulley information....
  25. Inglis, Whirlpool and Kenmore style dryers - belt change
  26. Inglis, Whirlpool and Kenmore dryer general motor problems
  27. Inglis, Whirlpool and Kenmore gas style dryers - no heat problems
  28. Inglis, Whirlpool and Kenmore dryers - where are my thermostats
  29. If your drum belt looks like either of these....change it!!
  30. Idler pulley slide troubles with newer Whirlpool build Roper dryer
  32. Newer style Whirlpool - Inglis - ( some ) Kenmore dryer front drum support ring install help
  33. Pilot flame help
  34. Sample wiring diagrams
  35. Test for ohm meter checking on electric dryers with no heat
  36. Taking apart an Duet or HE3 dryer for a belt change
  37. Taking apart a Whirlpool Thin twin washer/dryer to replace the belt
  38. Timers and some common Auto dry troubles and solutions
  39. What is a grounded element?
  40. Whirlpool - Kenmore dryer motor problems in the dryer with Even HeatControl....info on this is here  + new25.gifExpanded repair helps for a common "Even Heat" dryer
Mar 30, 2009 | Whirlpool LGR8648L Gas Dryer
12,538 people viewed this tip
Top Dryers Experts
Marvin
Marvin
jimorris77
