Tip & How-To about Washing Machines
Dryer not Working Dryer not Drying
If your cloths dryer seems to be not working like it did when it was new you may want to check out why. A couple hours of your time may pay huge rewards in drying time and efficiency. This tip will pertain to both gas and electric dryers.
One of the first things that you want to check is to see if the dryer is blowing air out of the vent. If the air coming out does not seem to be any or enough you have a bad blower fan assembly or have a clog somewhere that is restricting the flow of the air. This restriction could be either in the dryer or in the vent piping going to the outside.
Remove the hose from the back of your dryer and inspect the hose or vent pipe to the outside. Clean out all debris that has collect inside the piping. If the pipe has any sags they can collect lint in them. Keep the line to the outside as straight and short as possible. The more air that can flow through the better and more efficient the dryer will be.
Pull apart everything that you can on the inside of the dryer. To get to the parts your will need to pull off the back cover if your dryer has a top lint screen or the bottom front panel if your dryer has the lint screen in the door. Make sure that you unplug the dryer before opening the panels.
Cleaning out the dryer venting will give the heating components of your dryer a chance at a longer life. Excess heat is what will burn out the thermal cut-out fuse and also will cause the high-limit switch to activate much more often then it would need to otherwise. The heating element will also be running at a higher temperature which could cause a premature failure there also.
It is a good idea to learn to do these things on a regular basis to prevent part failures and also the possibility of a house fire. The build up of lint in your dryer can cause a fire. The more often you clean the unit the better protected you are. Cleaning four times a year is a good practice. This will give your equipment longer life and help to protect your property.
Keeping your dryer clean and the vent piping clean will help to ensure that your dryer is working at it’s best at all times. You also will feel safer knowing that you are doing what you can to keep you and your family safe.
http://www.fixya.com/support/r4312805-dryer_maintenance
http://www.fixya.com/support/r3866744-dryer_not_working_dryer_not_drying
http://www.fixya.com/support/r3907570-buy_appliance_parts_online
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
http://www.fixya.com/support/r4496386-dryer_cord_wiring_dryer_3_wire_or_4_wire
http://www.fixya.com/support/r4416566-dryer_repair_squeaks_grinding_clicking
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
Washing Machines Logo
My dryer is making my clothes soaking wet every time I put clothes in. How do I turn the warer off on the steam mode (I guess)
Same problem here....I have had my brand new Whirlpool Duet Steam front load washer for a whole 4 days... It has worked perfectly until now. I checked on the clothes because it seemed like they just kept going and going... they were soaking wet!! When I took the clothes out the dryer had a huge puddle of water in it..Can anyone offer any help?
Sep 30, 2010 | Whirlpool Duet Steam WFW9700V Front Load...
It seems like the burners are not all lighting. Maytag Epic Z gas
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer Troubleshooting2_bing.gif Electric2_bing.gif Dryer won t Heat
heatman101
May 11, 2010 | Maytag EPICz 6.7 Cu. Ft. 8-Cycle King-Size...
dryer takes 4-5 hours todry clothes dryer seems hot just not drying
HI, Check the following to address this issue further.
Note: Normal drying time for a dryer is about 45 minutes (some may take up to an hour).
1. Venting
Make sure the dryer vent hose, as well as the rest of the vent duct, is not clogged.
Unless regular maintenance is performed, chances are there is a lot of lint accumulated inside the dryer. This might affect the drying time and could be a fire hazard. Make sure to have your dryer cleaned regularly. Because this might involve taking most of the dryer apart, it is recommended to have a qualified appliance repairman perform this task.
2. Thermostat
There are a couple of cycling thermostats inside the dryer. If one of them breaks down, it might affect the dryer's performance. Replace the defective thermostat. These thermostats are located in the dryer vent duct and sometimes mounted on the blower assembly as well.
Dec 08, 2009 | GE Dryers
Clothes Not Drying well
1. Venting
2. Thermostat
Jul 31, 2009 | Whirlpool Dryers
Kenmore 110.69912990
Need more info. Check voltage at outlet. Check thermal fuse,
check thermal cut-off assy. Then you have question -what caused the thermal to fail? There are several.
Mar 17, 2008 | Kenmore 73952 Gas Dryer
20,998 people viewed this tip
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
