Tip & How-To about Husqvarna "Chain Saw - 16" Bar, 3 Hp
You need a block of wood,a large alligator clip,some nails,screws and wire and the cap end of an old spark plug.Make a hole of 3 cm in diameter in the center of the block of wood.Enter lateral in the block of wood face to face two nails,a short one from the right side and the longer one from the left side.They are set in the middle at 3/16 inch.The large alligator clip is attached to the block of wood with a screw and is connecting to the short nail through the wire.At the long nail is attached the cap end of an old spark plug.The wire from the coil is attached to the long nail and the large alligator clips to the cylinder.If the spark tester will produce a blue spark strong enough to jump the tester gap it is adequate for the engine to run.Now you can check the ignition system and you do not have to pay for this anymore.I wish you good luck.
