Tip & How-To about Washing Machines
Your washing machine is one of the hardest working appliances in your home. Read on to learn what you need to do before using your washing machine for the first time.
First things first, before setting up your washing machine, remove the transit bolts from the back of the machine. Keep the transit bolts safe and re-fit them if you need to transport your washing machine in the future.
It is important that your washing machine is level and securely positioned on all four feet. Use a spirit level to check that the machine is level. Incorrect installation may cause the washing machine to vibrate.
Connect your washing machine. Check to ensure that the hose is not trapped, kinked, twisted, folded or crushed. Once you have made all of the connections, carefully turn your water supply on and check for leaks.
Tests were carried out on your appliance at the factory and as a result, water may be left in the washing machine. To remove any water I recommend that the first wash is carried out without any laundry.
Here you can find some more helpful information.
