Tip & How-To about Washing Machines
Need a quick repairs of your appliences
At Care&Repair Appliances, you can book your repair at the most convenient time for you. We work all year round including weekdays, weekends and holidays, and always on evenings, holidays and weekends when you are more likely to be at home.
Washing Machines Logo
is the sunvic sp2 a 2channel timer please
Yes. It appears the Sunvix SP2 is 2-channel timer.
http://www.sunvic.co.uk/documentation/Programmer_Select_207.pdf
Two-channel means CH central heat and WH water heater can be programmed separately, and each can have its own timing program.
pg 3
The timer offers pre-programmed options for both CH and WH, which can be used, or program your own schedule. chart pg 5 and steps pg 3
Limitations: both channels operate on same clock time, and dip switch setting. pg 6. So the WH cannot be programmed for 5-2 weekdays-weekends and CH programmed for 24 hour.
As a convenience for varied work schedules, Sometimes people use the 5-2 weekday-weekend option so 2 days of week can have different programming, and then fudge current day setting during the set-current-time step pg2 so the 'weekend days' are actually moved to wedsday-thursday instead of sat-sun.
Option: both CH and WH timer programs can be linked and follow same programming by using copy button. pg 5
Using advance button on either side of timer, pg 3-4, WH and CH timing schedules can be overridden temporarily until next set point is reached. Then regular programming automatically resumes.
If override or Advance button is pushed for either CH or WH, it reverses whatever programming is in effect. On becomes off, or off becomes on. However if CH thermostat is satisfied and room temperature has not fallen below thermostat set point, then override will not turn CH on, but override will turn CH off. Same for WH override: If cylinder thermostat is satisfied with internal water temperature, the water heater will not turn on and heat more water, but the override can turn water cylinder off.
Unit requires Cr2033 lithium button battery. Pg 6. Probably lasts 3-5 years. Programming is protected for 30 days from power outage.
If programming is lost, change battery, the reset timer and reprogram to restore functionality.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
2005 avalanche service manual
2005 Chevrolet Avalanche 1500 Service & Repair Manual
2005 Chevrolet Avalanche 1500 Service Repair Manual Software Download...
LICENSED OEM SERVICE AND REPAIR MANUAL SOFTWARE FOR THE 2005 CHEVROLET AVALANCHE 1500!
If you need a repair manual for your Chevrolet, you've come to the right place. Now you can get your repair manual online in convenient digital format. Old paper repair manuals just don't compare! This online repair manual software covers the Chevrolet Avalanche 1500 and is perfect for any do-it-yourselfer.
In the dark old days of auto repair, you had to buy a traditional service manual in book format which would retail at a higher cost. Getting the same information in digital format is so much less expensive and more convenient!
Maybe you need the manual to fix the brakes on your Avalanche 1500, or possibly replace some worn out suspension components. Or you might need to get your engine running, or just do the required standard maintenance. Whatever the case may be, this repair manual software for the Chevrolet Avalanche 1500 is just what you need.
You will have all the service information you could ever need for your vehicle. It will help you fix the brakes, engine, suspension, steering, drivetrain, electrical problems, heat, air conditioning, etc. Anything can be fixed!
You can save a lot of money by working on your own vehicle. You probably already know this, but mechanics charge a lot. Do it yourself and use this 2005 Chevrolet Avalanche 1500 repair manual software to guide the way.
It gives you the manual for your Avalanche 1500 and it's very easy to use. It is compatible with any Windows computer including desktop PCs, laptops, smartphones and tablets.
License includes 1-year access to OEM service and repair procedures and unlimited access to supplemental data.
Downloadable service manual for 1998 cavalier 2.4
1998 Chevrolet Cavalier Service & Repair Manual Software
1998 Chevrolet Cavalier Service Repair Manual Software Download Manuals...
LICENSED OEM SERVICE AND REPAIR MANUAL SOFTWARE FOR THE 1998 CHEVROLET CAVALIER!
If you need a repair manual for your Chevrolet, you've come to the right place. Now you can get your repair manual online in convenient digital format. Old paper repair manuals just don't compare! This online repair manual software covers the Chevrolet Cavalier and is perfect for any do-it-yourselfer.
Maybe you need the manual to fix the brakes on your Cavalier, or possibly replace some worn out suspension components. Or you might need to get your engine running, or just do the required standard maintenance. Whatever the case may be, this repair manual software for the Chevrolet Cavalier is just what you need.
You can save a lot of money by working on your own vehicle. You probably already know this, but mechanics charge a lot. Do it yourself and use this 1998 Chevrolet Cavalier repair manual software to guide the way.
It gives you the manual for your Cavalier and it's very easy to use. It is compatible with any Windows computer including desktop PCs, laptops, smartphones and tablets.
were do i get a free service manual for a dodge neon 1995 ?
1995 Dodge Neon Service & Repair Manual Software
1995 Dodge Neon Service Repair Manual Software Download Manuals...
LICENSED OEM SERVICE AND REPAIR MANUAL SOFTWARE FOR THE 1995 DODGE NEON!
If you need a repair manual for your Dodge, you've come to the right place. Now you can get your repair manual online in convenient digital format. Old paper repair manuals just don't compare! This online repair manual software covers the Dodge Neon and is perfect for any do-it-yourselfer.
Maybe you need the manual to fix the brakes on your Neon, or possibly replace some worn out suspension components. Or you might need to get your engine running, or just do the required standard maintenance. Whatever the case may be, this repair manual software for the Dodge Neon is just what you need.
You can save a lot of money by working on your own vehicle. You probably already know this, but mechanics charge a lot. Do it yourself and use this 1995 Dodge Neon repair manual software to guide the way.
It gives you the manual for your Neon and it's very easy to use. It is compatible with any Windows computer including desktop PCs, laptops, smartphones and tablets.
Top Washing Machines Experts
john h
