Tip & How-To about Sony Playstation 4 Black 500 GB Console PS4
PS4 Won't Turn On Diagnois
Read up at this link.
PS4 Won Turn On Diagnois
SOLVED PS4 beeps once then turns off PlayStation 4
PlayStation 4 will not power on Google Search
Sony Playstation 4 Black 500 GB Console PS4 Logo
2answers
How to fix a ps4 that needs a software update via usb
First, from your computer click the Download Link
to download the latest PS4 Update. Make sure you don't rename the downloaded file.
After download, plug your USB onto you Computer. Open the USB and make a folder inside named PS4 (you need to use Uppercase letters). Inside that folder create another folder named UPDATE. Then, just take the PS4UPDATE.PUP file you downloaded from the provided link and put it inside the UPDATE folder.
After that you just connect your USB with your PS4, and then from the Main Screen of your PS4 go to Settings -> System Software Update and just follow the instructions on-screen.
PS: Make sure you DO NOT turn off the console or remove the USB from the PS4 while the update is taking place, otherwise the system may be come temporarily or permanently damaged.
Download Link
http://dus01.ps4.update.playstation.net/update/ps4/image/2015_0625/sys_4f1c6d8597242ff346612773ffbc10ad/PS4UPDATE.PUP
My ps4 turns on then right back off help
Make sure your HDMI connection is secure, and in the right place. The PS4 has the same feature as the PS3, that it won't power on completely if it doesn't detect a video source.
2answers
playstation 3 powers up but doesn't load to menu page, just green background screen present. Green and blue lights on on console. Have tried disconnecting and reloading, Have cleaned the disk and checked for damage to disk but no change. Any ideas?
1. Turn off PlayStation 3.
2. Hold the power button down; the system will turn on and turn off once again.
3. Once the System has been shutdown, re-press you finger until you hear 2 consecutive beeps
4. When you hear the 2 beeps take finger off power button.
5. You will be prompted to plug in your controller via USB and then hit the PS button
6. The Recovery menu will pop up.
7. Choose to 'Restore File System' and follow the process through.
My playstation 3 screen is green and light blue. It takes updates but wont read discs.
For the recovery menu:
1. Turn off Playstation®3.
This will get you to the Recovery menu, all you have to do is click ReBuild. And just turn your ps3 off and on again.
wont read the disc .my sony playstation 3 wont read any disc.
The PS3 has a special Recovery Menu, which you can access in the following way:
1. Turn off Playstation 3.
The current Recovery Menu supports:
• Restart System: Restarts the PLAYSTATION 3 System.
• Restore Default Settings: Reset all system settings back to default.
• Restore File System: Checks for corrupt/missing system files.
• Rebuild Database: Rebuilds the OS for the PLAYSTATION 3.
• Restore PS3 System: Fresh restore; Deletes everything and starts from Scratch.
• System Update: Update the PLAYSTATION 3 System
From the above select option "Rebuild Database". After PS3 has executed this DB rebuilding operation, the disc games will be visible again in the menu.
Top Sony Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Accurate TV Repair...
Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
