Tip & How-To about Bell & Howell Video Cameras
If you have broke something what do you do
If you have broke something i wouldn't keep it a secrut i would tell straight a way even though you could be scared to tell still do co time me on you can do it just say that your sorry and dont ever do it a gian tell tehm they can punish you if they want act like you dont mind and dont shout at them just stay calm and say you sorry and whatch out next
Video Cameras Logo
99 Olds Cutlass, new ignition problems
Obviously the mechanic is not getting down to the real
issue for some reason
Try a different shop
I can only guess but it sounds like you may need
a new ignition switch & then the proper adjustment
if one is required
You may be able to dajust yours to work ok if that
applies.
Seems odd the mechanic spends all that time in one area
& doesn't have a solution
You may have a bad door switch as well
yfz350 banshee kick start bound up
pull the kicker case cover, probably something simple jammed up in there...if you didnt break her in keeping revs under 2000rpm for 10-20 hours you may have broke something internal again, lets hope not
bobbin case wont stay in place
the bobbin case may need to be replaced. it wouldn't hurt to have the machine serviced to make sure the hook & hook race are ok
The needle keeps breaking. The needle seems to be hitting something or getting caught when it goes down and then it breaks off. I can't even get the needle to pick up the bobbin thread because it breaks off before it can complete a full downward/upward stitch.
Certain stitches you do, require different base plates...by the base plate, I mean the metal piece that the needle passes through when it goes down through your cloth and through the hole provided...This sounds like why it's breaking, I think your needle is hitting the plate under it. It may not be all that obvious, but it wouldn't take much to snap the needle. You may want to check your setting and make sure it's setup to do a regular stitch. If that's not it, then you need to make sure that the needle is in straight, though I believe putting on in crooked is hard to do.
I hope this helps.
Top Bell & Howell Video Cameras Experts
ADMIN Andrew
ADMIN Andrew
Tony Parsons
Tony Parsons
Are you a Bell & Howell Video Camera Expert? Answer questions, earn points and help others
