Tip & How-To about Kodak EASYSHARE M1063 Digital Camera
Try removing and replacing batteries to reset the camera. Ensure that batteries are fully charged.
If that does not clear the problem, then the lens error is
usually caused by mechanical faults concerning lens
assembly. This happens because there is dirt inside the lens (sand
dust), or one part in the lens assembly is bad or went out of place.
Because of this he lens cannot extend or retract fully, the error is
detected and lens error is returned.
Sometimes this can be fixed
playing with the lens during extraction or retraction to help the lens
asset getting back to normal.
If if does not extend tapping gently the back of the camera, and if it
does not retract helping lens back in while turning camera respectively
on and off.
More often the camera lens must be disassembled and re-assembled by a technician to fix the problem.
Using an Initialize option in the menu
Since Cyber-shot cameras have different menu system layouts, refer to the instruction manual specific for your camera model.
Using a RESET button
Performing a manual power reset
