Tip & How-To about Samsung LN32A330 32 in. LCD TV
SAMSUNG LCD Panel - TCON board troubleshooting
SAMSUNG LCD Panel Repair - TCON board problems
Don't handle the Panel under the Power-On.
And for disassembly, you have to wait more than 5minute after power off
If you feel any strange sound, smell or smoke, then need to remove the power
Don't handle the Panel in the Dust and Dirty place.
Don't handle the Panel with wet materials, especially hands
Hold the Connector body when you remove or assemble any cable.
AbnormalDisplay
Distortion and unstable picture
Control Board (T-Con) Change
NoDisplay
Only Black or White Screen is displayed but BLU is on.you can check if the backlight is on by pressing the screen slightly.
Color is not Displayed.
Possibly the cause is Fuse open
If you wish to get some details; check the site linked here.
http://electro-medical.blogspot.com/
Samsung LN32A330 32 in. LCD TV Logo
Why does the screen turn white after 10 minutes?
Probably the t con board have problem. the power regulator ic on the tcon board make this problem. As ist an smd ic you have to go for a new tcon board, because its not possible to replace the ic with normal soldering irons. you need smd rework station for that purpose. And also on more thing in some tvs the t con board is integrated to the lcd panel. if so its not possible to replace only the t con board , you have go for a fresh lcd panel. it would be a costly repair. because the panel is the costliest part of the tv. Any why check the video to understand which one is the t con board. if you find one in yours then try to replace it with new one. hope your problem will solved
www.electro-medical.blogspot.com
LCD TV Repair Tutorial Con Board Common Symptoms Solutions How to Replace...
Nov 03, 2015 | Samsung Televison & Video
my tv sony bravia 46" are still not workin i still
Don't return the new refurbish tv power supply board,keep it and used it the old one u have it in ur tv it is shorted and dead already.Return those LCD inverter boards though.Should buy a main tv Tuner signal board and replace it too though,that the other board it is causes and it is also dead too.Repair this problems many times before,alway these two boards are dead.I promise u the tv now will have stable power supply again tv will work again.
Jul 15, 2011 | Sony BRAVIA KDL-46W4100 46 in. LCD HDTV
we are having SAMSUNG LA37R81B tv at home its showin blurred picture we asked repair man he said we need the tcon board number so that we can buy we now need your help
it possible that the problem is the the TCON board, you can try websites Shopjimmy.com,Ebay.com to buy a refurbish board for the replacement.
Also note that
The T-CON (Timing Control or LCD controller) board (on the LCD panel assembly). It transfer the universal image signal of TTL and LVDS signal to specific TFT (Thin Film Transistor) LCD.
This is the interface board that talks to the Logic board and the LCD panel to produce pictures on the screen. White/gray glowing screen when it fails or not getting the voltage from the logic board (the 5 or 12vdc is supplied by switched transistor on the logic board). Notes: T-CON board is mounted under the metal cover shield.
Common failures:
Scrambled pictures, Lines, multiple pictures, color smears/blotches, rolling pictures after warm up.
Blown surface mounted fuse.
No pictures, very dark screen almost like there is no backlights.
Hope this helpout..
Jul 30, 2010 | Samsung Televison & Video
LNS4692D - TCON Board (seems there is a systemic issue)
You have to be very careful with the flat ribbon cables and be sure not to have an electro static discharge to the board while handling it but it is not that difficult of a repair. It is the board that is located at the top center of the back of the lcd panel. Depending on your problem, eg. line in picture, no picture with backlight.... it unfortunately only fixes about half of the units. The other half need lcd panels which are very expensive. hope this helps.
Mar 25, 2008 | Samsung LN-S4692D 46 in. LCD HDTV
Samsung LE40R51B no picture but turns on
i have the same problem i was told by a repairman that samsungs are known for bad psu. and that its expensive to repair
Nov 20, 2007 | Samsung LE40R74BDX 40 in. LCD Television
1,994 people viewed this tip
Jerry Greenberg
Jerry Greenberg
Ekse
