Tip & How-To about Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
How to enter the Service ModeService adjustments to this model can be performed using thesupplied Remote Commander RM-ED011W.
ON SCREEN DISPLAY > DIGIT 5 > VOLUME + > TV POWER ON1. Turn on the power to the TV set and enter into the stand-by mode.2. Press the following sequence of buttons on the Remote Commander.3. The menu will appears on the screen.4. Move to the corresponding adjustment item using the 'UP ' or ' DOWN' arrow buttons on the Remote Commander.5. Press the 'RIGHT ' arrow button to enter into the required menu item.6. Adjust the data value using the ' UP' or ' DOWN' arrow buttons on on the Remote Commander.7. To go back at any time press the 'Return' button on the Remote Commander.8. Press the 'Menu' button on the Remote Commander to quit the Service Mode when all adjustments have been completed.
www.electro-medical.blogspot.com
SETTING THE SERVICE ADJUSTMENT
MODE
1. Standby mode (Power off).
2. Press the following buttons on the remote commander within one
second of each other:
DISPLAY Channel 5 Sound Volume + Power
READING THE MEMORY
1. Enter into service mode.
2. Press 0 on the remote commander.
3. Press ENTER to read memory.
ADJUSTING THE PICTURE
2. Press 2 or 5 on the remote to select the device item.
3. Press 1 or 4 on the remote to select an item.
4. Press 3 or 6 on the remote to change the data.
RESETTING THE DATA
Note: Be careful when using the remote! It will clear and re-initialize
ALL NVM data including defl ection adjustment data if not reset
properly as follows:
5. Press MUTING then ENTER to write into memory.
RESETTING THE DEFLECTION NVM DATA
2. Press 7 , then MENU, and then press ENTER on the remote.
RESETTING THE SYSTEM NVM DATA
2. Press 7 , then 9 , and then press ENTER on the remote.
2. Press 8 and then press ENTER on the remote.
MEMORY WRITE CONFIRMATION
METHOD
1. After adjustment, pull out the plug from the AC outlet, then replace the
plug in the AC outlet again.
2. Turn the power switch ON and set to Service Mode.
3. Call the adjusted items again to confi rm they were adjusted.
Ok.
