Tip & How-To about Sharp Office Equipment & Supplies
Lease a Copier Vs. Purchase A Copiers - Pros and Cons
Today I am addressing the pros and cons of purchasing a copier vs. leasing a copier for your workplace. I was recently asked this question for the 5,000,000th time and I decided to answer the question publicly. If you feel like you have unique circumstances feel free to contact me directly to ask a question.
There are advantages and disadvantages to either acquisition process. There are several variables that will help steer you in the right direction to see whether purchasing or leasing a printer is right for your office. Whichever option you decide on, you can rest assured that Skelton Business Equipment will take excellent care of your machine with a recommended maintenance and toner contract.
Leasing:
  • Pros
    • No acquisition cost
    • Cheap monthly cost
    • Rotated new equipment
  • Cons
    • No ownership
    • Extended obligation
Purchasing:
  • Pros
    • Instant ownership
    • No extended obligation
  • Cons
    • High initial cost
    • Potential for old non-functioning equipment
    • technology quickly becomes obsolete
Ask yourself these three questions:
1.) How long has our company been in business?
The credit approval process can be very sensitive to new businesses. Without 3 or more years in business the lease application will probably require a personal guaranty from the owner of the company. With that being said, it may make more sense to purchase a refurbished printer at a low cost, then lease a more robust, new printer down the road once the company has more established credit and higher printing volume.
2.) How much do we print?
Printers these days are designed to last! If you don't have a high volume of printing you'll probably get more bang for your buck purchasing an MFP outright. Most lease terms are 3 or 4 years, and if you aren't simply pounding your printer all day every day, then you should get a lot more than 3 or 4 years out of it. On the other hand, if you hammer your office equipment, it makes more sense to lease a machine so you'll get a new one at the end of the lease term and not have to worry about what to do with a broken down machine 8 years down the road. A headache is the last thing you need with office equipment, you have a lot of other things to worry about. And so do I.
3.) How much are we willing to spend out of pocket for a printer?
Large MFPs can are expensive. Leasing them is a great option for an office without a large budget. Most workplaces would function seamlessly with an MFP for around $200 a month, which would cost you nearly $7,000 cash. You could lease a machine that's out of your budget that will handle a larger workload than a system that was purchased outright.
With these questions answered you'll be on the right path to either purchasing or leasing a copier. If you're looking for a copier in Houston I give rock-bottom pricing, especially if the lead comes from this blog.
Looking to purchase a roughly 20 gallon mediocre air compressor. Which Harbor Frieght compressor would you get on a budget?
That is exactly what you will get, There are no repair parts. buy oil lubed compressor. be aware that the comp may not deliver enough air at high pressure for task.
MCGRAW 21 gallon 175 PSI Oil-Free Vertical Air Compressor
CENTRAL PNEUMATIC 29 gallon 2 HP 150 PSI Cast Iron Vertical Air Compressor
What are the pros and cons of a bait-casting reel vs. a spinning reel?
Spinning Reels Pros:
    ·Smooth
    ·Hard and tough anodized body
    ·Strong and stable pulling ability
    ·A beauty to look at
    Cons
      ·Painted pool
      ·Quite heavy
      Baitcasting Reels Pros
        ·Light and sturdy- Easy flick, and as little as possible stress on the wrists
        ·Devastating drag power of 16.5 lbs.
        ·Comfortable grip and palming for efficient casting
        ·Dual braking system allows a lot of ways to cast your line
        ·Inexpensive for its features
        Cons
          ·May need factory grease
          ·Dual brakes are hard to master
May 29, 2018 • Fishing
Top Sharp Office Equipment & Supplies Experts
k24674
ZJ Limited
ZJ Limited
Norman Weimar
Norman Weimar
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
