Tip & How-To about Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC
This is quite a vague & general question, but some of the ways you can optimise performance of yor PC are:
1. There are so many programs which think you need to use them all the time, that they put themselves running when they start up. Examples of these are Yahoo Messenger, MSN, Nokia PC Suite, etc, etc. Most of these will have an icon in the system tray (lower right beside the clock) You can right-click on these, and choose exit, but this is only temporary, they will re-appear when you next start up your PC. To completly prevent them from starting up next time remove them from the startup folder on the start menu:
You should also remove programs which have placed themselves into the registry to start up.
2. Ensure your anti-virus is up to date. Most newer anti-virus softwares do this automatically, but you can force an update by right-clicking the icon in the system tray (lower right beside the clock) and chosing 'update'. If you do not have a working anti-virus software, there are several high-end free ones out there such as Avast and AVG.
3. There are several 'stores' of information on your hard drive which are taking up a lot of meaningless space unless you keep on top of them. These are items like the internet cache, the recycle bin contents, temporary files. These can all be cleaned in one fell swoop:
There are also a number of temporary folders on the hard drive wich are normally quite safe to delete the contents of.
4. While all the other fixes so far have been quick to perform, defragmenting the hard drive may take some time depending on the size of the hard disk - hours, days, or in some cases, weeks.
Over time, old files get deleted from the drive, and new ones are written, often over the data which was deleted, but the space for the file going in may not be large enough, so the drive puts some of the file in the space available, and the rest of the file elsewhere on the disk. This is invisible to the user, but the drive knows where all the bits are, and puts all the bits back together when the file is opened. Think of it as a large filing cabinet which is ordered alphabetically, where all new files going in are just placed at the back, when a file starting with say G is taken out, it gets put back behind all the other files following Z... Over time, the filing cabinet needs to be re-organised. This is what defragmenting the drive is doing... taking all the files which have been broken up, and putting them all back together on the disk. By having fragmented files, the hard drive takes longer to retrieve the files, often having to go back & forth across the drive instead of just reading the file in one go. To defrag the drive:
As stated earlier, this can take some time to complete. Some steps you can take to speed up the process is to reduce usage of the drive while the defrag is running:
By performing all these processes, you can potentially speed up your PC by up to 50% or more. (Depending on how frequently these steps are run... if ever!!!)
Hope this helps.
